Some mp3 albums will not show up with there Tagged file names after I drag n drop them onto my philips mp3 player. When its still connect to the pc it shows them there and I can double click on the to play them, but once I disconnect it from the pc they loose all there information. And when I plug it back into the pc it shows the files as Blank with a unknow file image instead of the usual mp3 image. And its properties says each file has 0kbs and 0 file size yet it still plays them!? All I want is for them to read the id3 file name I tagged them with. I have alot of albums on there with no problem but like four or five are screwing with me. One album has 15 tracks and only 3 show up like normal. I have used Multiple programs including the one it came with, changed formats, renamed , retagged over and over , Please Help
Re: Mp3 Files Show as Unknow under artist and title
Get the latest version of the software from the Philips website - it is more recent than the installation CD. Go to: www.usasupport.philips.com Enter your model number On the next page, click on your exact model number without the "B" on the end On the next page, click on "software and drivers"
Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
you wish to combine music from the same artist or various artists? the same artist will go under that artist name... various artist you will create a folder (play list... slow jams, dance tracks or even genre)
example Hip Hop will be all in one folder or all My Chemical Romance live / studio in one folder
connect device to PC, start/my computer/see device open it, right click new folder... now open new window find files click and drag or copy and paste files from where the files are to the newly name folder
note once you finish do not disconnect... disconnect using hardware removal safely
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Sync to your windows media player....Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar click Choose Columns put a check next to Genre, Rating, artist and album artist whatever you want. Right click song under artist and edit same with album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your media player then load songs to it........Or drag and drop
You really should NOT try the "drag and drop" from a DVD - it'll end up making symbolic links ("aliases") to each of the files rather than copying them into the iTunes library. If you click on them in iTunes on your computer WHILE the DVD is mounted they'll probably play, since it can "find" the original files. But your iPod can't "play" them from your DVD, can it? So either COPY all the MP3 files onto your hard drive from the DVD and THEN drag them onto the iTunes "Music" library icon or, instead, in the File menu, select "Add to Library" and select them from there. Oh, and first delete all those dead links with the little grey "x" or question mark by the name in your iTunes music main window to make it easier to tell the new "good" ones you add afterwards (do this with DVD removed).
Open Windows Media Player 11
Right click on one of the songs that is showing up as unknown artist.
Select "Advanced Tag Editor"
Manually enter the artist information, etc.
To save time, you could also right click the song and select "Find Album" info - it won't find every album, but it will find most of them.
The real bear is that once you have edited the information in Windows Media Player, you have to delete the affected song off of your mp3 player and THEN reload the newly-edited song - or else your changes won't register on the mp3 player itself.
If you're using MSC mode (moving files via explorer), I believe the player ignores the directory structure for the most part, and uses the MP3 tags. I've had very good success using Media Monkey (which is freeware) to group the songs, and then transferring from there, in MTP mode.
You will need to right click on the song file to see if the ID3 information is present.
Right-click, Properties, Summary tab.
You shoudl see a list of fields that you can populate manually, or you can try loading your audio files into a media manger program like iTunes, Media Monkey, WMP, etc and insure your song titles and album names are correct in the ID3 tag fields. Then, your files will appear correctly on your player.
The funny~.mp3 names are usually because the title field is not filled in in the mp3 property tags, so it uses the DOS version of the filename for the title. Under windows, right click the song and select properties->summary->advanced, and make sure that the title field under "description" has what you want in it. I don't think even the makers of Ilo know how it organizes the files.
All files need to have filenames and titles ("title" field in the summary under file properties on your PC). Otherwise the player will list it as "unknown" and it will NOT play. You have to drag it out of the player, rename, and then drag it back, if you're in MTP mode (which you SHOULD be!).
Multiple copies of the same track sounds like you have some tracks listed under different artist names--you gotta keep a clean library!! Go back and check all the summary attributes for your mp3 files...
Of course, you're using WMA files so who the heck knows. I would be sticking with mp3 format, if you want my opinion.......
