Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series won't drain or spin
After filling, the motor hums/buzzes and nothing happens.
I pulled the pump and with the pump removed, and on spin cycle, the motor only spins.
When I put a small crescent wrench on the motor shaft where the pump would connect to, I can move the motor clock wise and the drum spins. It seems to be a reasonable amount of resistance.
I removed the motor and with no load, the motor would only buzz and not even spinn. When I help it spin with my fingers, the motor kicks in. As long as it is still spinning, with the switch, I can turn it on and off repeatedly.
There appears to be some sort a braking mechanism on the motor its self.
Is there a repair for the motor, or do I just need to replace it?
Thanks,
Daren
  • 487 Answers
Hi Daren
fill in this site your model number in and it will guide you to all the diagrams you will need and all the parts
HERE
Posted on Sep 28, 2009
I have a Kenmore 600 washermachine it won't spin or rinse. It would fill up with water and go all the way through the cycle until it got to the last rinse cycle and just stop and make a buzzing noise...
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
p.s the buzzing noise is the water pump humming because it can not spin the problem is definitly your water pump have it repplaced and it will work fine
please take the time to rank my reply if your happy with it.
Dec 01, 2010 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer 20712 series 70 will fill but nothing else
Check at the back side of the motor to see if it turns freely. If it does, your motor is bad. If not your gearcase is frozen (bad). Hope this helps!
Feb 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
121 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
