Question about Cameras
E04 error, safeguard mode.the unit is in safeguard mode. remove and re-insert the tape.and if i try this error continues to appear
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
Arpi
  • 326 Answers
SOURCE: E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Posted on Jun 08, 2007
eagle338
  • 4889 Answers
SOURCE: E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Posted on Oct 18, 2007
ginko
  • 19396 Answers
SOURCE: I have a dvd camcorder-
Did you try removing batteries to see if it clears error?
this is first thing to do.
Posted on Aug 09, 2008
SOURCE: Camera is a JVC GR-DF470
Same problem, same camera. Interestingly, it happened after two years and coincidentally when I changed to a different brand of tape (TDK) after using Sony and JVC tapes.
Solution (as suggested on some other web site) is to eject and then manually wind the tape a couple of turns. This can be done by sticking one flat blade screwdriver in the tape locking tab (bottom middle of case) and using another to manually wind the tape reel. Re-insert the tape and there should be no error code and all should work fine.
Hope this helps.
Posted on Aug 31, 2008
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
E04
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
