Question about Canon Pixma iP6000D InkJet Photo Printer
I got a warning that the out paper tray is open which is not true i don't know what to do to fix that problem
    Sergeant:
    Champion:
  • 269 Answers
Pull the paper tray out and try reinserting it .There is a micro switch in the paper tray slot that activates this message.If this does'nt correct the problem go to Canons' website for tech help
Posted on Sep 28, 2009
Trays locked
Look for a small pin hole on the front of the CD tray area. Take a straightened paper clip or a pin, push it into the hole until you feel resistance. Then press the eject button at the same time as you press firmly on the pin or paper clip. The tray should open. May take a few tries as you have to get the timing right. Good luck with it and I hope this helps.
Dec 23, 2013 | Philips Audio Players & Recorders
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
The printer wont load the paper in anymore it will grab it on the left side but not the right
Please help me here. What model printer are you using?
Does it have multiple paper trays?
More then likley, the paper feed rollers are either worn or contaminated with paper dust and are not letting the paper be grabbed and pulled from the tray properly.
It could also be the paper pick solenoid not mechanically pushing both sides of the spring loaded tray up into the paper feed roolers. Or in the case of a true paper tray, preventing both sides of the tray from lifting with the same force.
Don
Oct 17, 2009 | Dell 924 All-in-One InkJet Printer
Display says "Close feeder 1 Cover"
close the back door of the paper tray 1. the paper tray for this printer actually has a "door" that opens up. silly but true
May 20, 2009 | Dell 3110cn Laser Printer
ImageRunner 2020 paper tray open warning - cannot fix
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Apr 08, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Paper jam and now printer wont work since all paper has been cleared out of printer
paper pick-up rollers may be warn out.replace rollers.tell me the company &model no.
Aug 04, 2008 | Office Equipment & Supplies
Muratex F98 Optional Paper Tray
THE PROB WITH THE PAPER TRY WOULD HAVETO BE FIXED FIRST...YOUR ONLY OTHER OPTION IS TO REMOVE THE 2nd 500 SHEET TRAY COMPLETLY AND ONLY WORK WITH THE 150 SHEET TRAY.
Jan 23, 2008 | Muratec F98 Plain Paper Laser Fax
Canon Pixma iP6000D InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
