Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Color convergence out of order .three colors out of order.
  • 647 Answers
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Posted on Sep 28, 2009
The three colors are separated and will not show as one picture I hard a pop before this happened but all three bulbs look like they are working
The tv now have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix the convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Jan 17, 2011 | Hitachi Televison & Video
The picture shrinked and the colors are one on top of other
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Hitachi Televison & Video
Color convergence and color looks 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 24, 2010 | Sony KP43T75GRAY 43" Rear Projection...
It is like looking at 3d in all three colors. i
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
May 30, 2010 | RCA D52W19 52" Rear Projection Television
I have some distored blue color across the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
COLOR CONVERGENCE PROBLEM COLOR SHAWDOWS WE HAVE
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 23, 2010 | Philips 51PW9363 51" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
What is the difference between a color wheel and a color conversion kit on a Samsung HLP4663wx
HLP4663WX is a DLP which has a color wheel. The DLPs dont have convergence circuits since there is only one light source. Projections with three CRTs have convergence which is the alignment of all three CRTs ( Picture Tubes)
Jan 05, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
