Question about Desa International CBN30T Central Heating System Heater
Can CBN30T be converted to Propane-If so how? If
Can CBN30T be converted to Propane-If so how? If not- how can I exchange this new unit in for a propane unit, since the company has filed bankruptcy
  • 615 Answers
You need to change the regulator and the handle that adjust the amount of propane get in ( I believe they called it Orpheus)turn the unit on propane. Take the old ones to hardware store and see if they can give you replacement…you need to check with a local store so they can test your unit....let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 28, 2009
Is it possible to convert a natural gas heater to propane
Sorry but it would not be worth doing all the work and spending lots of money buying parts, it would be better to buy a new one.
Oct 20, 2017 | Heating & Cooling
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
How to convert a 61" residential rangefrom butane to natural gas?
Ranges come set from the factory for natural gas. To convert it to propane, you should call your propane co and have a qualified serviceman do the work. You can void the warranty if you try to do it yourself and break something or don't convert it correctly. On an expensive range like this, you'll be better off having a professional do it right and keep that warranty intact. It could take 1 1/2 to 2 hours to complete the job. You may need to purchase an LP conversion kit if some of the orifices have to be exchanged, like on a unit with sealed stovetop burners. Write down the make, model # and serial # for reference when you make an appt to have it done. Hope that helps.
May 22, 2010 | Imperial Commercial Cooking Equipment...
Convert natural gas to propane
The unit when new would have come with a spare set of gas jets for the top burners which should be included in the manual.If not then you will have to get in touch with your supplier.These jets will have numbers on relating to the table in the book.
Hope this helped.
May 10, 2010 | Garland H284-24G Kitchen Range
I have a hayward H200 series heater and th eheat exchanger is leaking. I have pulled the heat exchanger out and cant see anything visible it is probably leaking inthe area covered by the fins. I have...
You need to buy the whole unit as these are pressed in place together. If you have a leak it is most likly due to chemical damage and goes further. So at the least you will need an exchanger. I will usually try to get people to go with a new heater if it is more than a couple of years old due to cost and hidden damage that can only come out after you install a new exchanger. Sorry for the bad news.
Mar 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Where is the model # located on my Comfort Glow propane heater?
Just went down in the basement and checked on mine. Looking at it from the front there is a lable on the left side near the bottom. Mine has the model right on the top of the label. CBN18C is my model number, your should be similar to that, only it may have a LP instead of the N mine is natural gas....
Heatman101
Jan 08, 2010 | Desa International CBN30T Central Heating...
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Open Questions:
Desa International CBN30T Central Heating System Heater Logo
115 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
