Question about HP Compaq Presario F730US Notebook
MY TOUCH PAD IS NOT WORKING WHEN I CLICK ON MOUSE IN CONTROLL PANEL IT SAYS UNABLE TO CONNECT UR SYNAPTIC POINTING DEVISES
Are you sure you didn't turm it off accidentally. There is a tiny little button at the top of the touch-pad to disable the pad. Look for the tiny little light blue is ON orange is OFF.
Posted on Oct 06, 2009
  • 615 Answers
Try to use external one for now and try to go and download another driver just to see if it is hardware or software, if the new driver gave you same error that mean you need to replace the pad....let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 28, 2009
  • HP Master
  • 8,404 Answers
Reload the driver.
Remove the driver via the Device Manager. Reboot. Windows will do this task for you.
I hope this helps you
a
Turn on touchpad
If you are having problems with a laptop touch pad, in control panel, (accessible from your start menu) on top right corner change your view to small icons, and there should be an option for mouse that you can click to access the mouse settings. Likewise you may have a link to a vendor specific mouse software like synaptics pointing devices or the like, that should give you the options necessary to turn touch pad off and on.
Jan 16, 2014 | Computers & Internet
Double tap working
do you have a 'synaptics based' touch pad?
try;
- re-calibrate your mouse properties in control panel
- reinstall the touch-pad driver
Nov 25, 2013 | Acer Aspire One D260 Netbook
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Help. I want to disable the touch pad on my Gateway M6866 laptop. Whenever I am typing and get near the pad, the typing goes all over the screen. Any help will be appreciated.
Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Mar 13, 2011 | Gateway M-6866 Notebook
My synaptic pointing device stop working ..I think
Since you do not specify the model number for your HP laptop one cannot be too specific. On my Toshiba laptop activation and deactivation of the touch pad is enacted by pressing the Fn-F9 sequence.
The actual Function key to press after the Fn key might have the picture of a touch pad on it. Examine tour laptop keyboard.
Jul 06, 2010 | HP Computers & Internet
Unable to connect to the synaptics pointing device driver
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign.
If synaptics is listed right click and select Uninstall.
After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Thanks for using FixYa - If you
Apr 29, 2009 | Logitech Marble Mouse Trackball
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Sep 04, 2008 | Dell Latitude C610 Notebook
Inoperative touchpad scroll zone
rwertheim,
I have a MX8711.
I assume you are running Vista.
After you have updated your virus protector program and run a complete scan. You "could" be fixing it and if it is a virus problem, it is immediately reinfecting the driver. If it still doesn't work, I recommend you:
1. Rollback the driver of your touchpad. If it was working, this might do the trick. You can do this at Control Panel > Mouse > Hardware (tab) > Properties (button) > Driver (tab). If it has been updated and that caused the problem, you probably can "Roll Back" to the previous driver and that option will be highlighted.
2. If not, then your driver is probably corrupted. Go to Gateway Support and download the touchpad application file for your computer and SAVE IT TO YOU DESKTOP AND DO NOT RUN IT. Replacing only the driver usually doesn't work in these cases but try that first. Go to Control Panel > System > Device Manager > click on the (+) sign by mice and dbl click on the Symantics PS/2 Port Touchpad (or what ever yours is) > Driver (tab) > Uninstall. When you restart, it should reload the driver from the application that is still installed.
3. If that dosn't work, I recommend uninstall the application from Control Panel > Programs & Features. Restart your computer and install the application you saved on your desktop.
I hope this helps.
Have a blessed day.
Tracker Tom
Apr 09, 2008 | Gateway MX8711 Notebook
HP Compaq Presario F730US Notebook Logo
263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
