Question about Dryers
I need to change the plug on the drier but the new plug has 4 wires and the back of th drier only have 3 places. how do i connect it
  • Dryers Master
  • 8,404 Answers
Run the Green wire to the frame of your machine. You will also need a new plug and maybe a new wire back to your power panel.
This may be a job for a pro unless you are familiar with 220 and heavy conductors.
Posted on Sep 28, 2009
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
I have a Maytag dryer (not sure the exact model #). I need to install a 4-wire power cord. There are three primary internal connections. Appears to be blue, white and black. But, 4-wire power cord has...
The laws in most states are changing to where the NEC2.gif Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Oct 10, 2009 | Dryers
I bought a roper with a 3 prong but i need a 4 prong. i bought a 4 prong plug but I don't know where to connect the left over wire in the dryer.
The laws in most states are changing to where the NEC Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
Oct 09, 2009 | Roper REX4634KQ Electric Dryer
Maytag drier de7600 connected new power cable to the 3 prong terminal on back of drier ground wire to the middle prong and the other wires to first and last. Drier does not start. What's wrong
check the breaker and make sure youturn it all the way off and all the way on. if you have a volt meter check the voltage from the two outside legs you should have 220volts
May 28, 2009 | Dryers
Changing 3 wire to 4 wire cord on dryer [electric type]
If you had a 3 wire system and need to adapt your drier to a 4 wire system.. here is how you do it.. Your 4 wire cord should have the following colored wire ends.. Red, Black, White and Green.. The red and black are the power leads and should be attached to the red and black terminals on the back of the drier.. The White wire is Neutral and should be terminated on the white terminal of the drier.. The green wire is Ground and should be attached to the nearest frame or chassis screw at the point of entry into the drier.. If you are using a metal cable clamp as part of a feedthru system to get the cord into the drier.. you can attach the green wire to one of the screws on that.. but that should be done only if you canot find a suitable frame ground screw near the terminal block.. Hope this helps...
Aug 30, 2008 | Dryers
Dryer plug issues
for 3 wire Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
for 4 wire Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Jun 09, 2008 | Frigidaire GLER642A Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
