Question about Whirlpool LER5636P Electric Dryer
The dryer runs fine, but there is no heat. I
The dryer runs fine, but there is no heat. I checked the lint line from the dryer to the wall and cleaned the lint trap and area with a lint brush. Help
  • Whirlpool Master
  • 909 Answers
You will find the heating elements on the driers are very robust. Normally what happens is there is either a build up of lint which has possibly blocked the air inlet grid,.or possibly being to close to the wall. This in turn restricts cooling airflow .There is a thermal protection thermostat which will activate and open circuit if temperature is exceeded at any time.Need to locate the thermostat and if lucky, you could simply press a button and it will reset. If not, you may need to replace that defective one. Typically the thermostat is at the back and close to the element.
Posted on Sep 28, 2009
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
Dryer has heat but clothes are still wet we dryed a dog pillow that came open and the stuffing went all inside. we took the back off and the shoot for the lint trap but there was no more lint.
If your machine is running properly and you have heat as you say then you may have a clog in the main vent line from the dryer through your house.
Try running the dryer once with the vent hose disconnected. If it dries your know the clog is in the house's vent line. Unusual but it does happen if you have a lot of lint.
Check first at the immediate opening point in the wall there is often a 90 degree elbow where lint can trap.
The other place is the cover plate on the outside of your house. Some at are static and others have vents that open and close. Those too can trap lint and cause a problem.
If you know you have a clog in the house line somewhere but the opening and exit are not clogged then take a drain auger (same as used to clear a clogged toilet) and run it through. If you don't have one try your garden hose.
Good luck.
Please rate if this gives you some direction.
Mar 13, 2010 | Kenmore 62602 Electric Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
RUNS AND HEATS UP BUT THEN QUITS LIKE IT OVER HEATED
Check for good air flow from wall end of flex hose. If weak, remove the lint screen and retry. If now ok, soak the lint screen in detergent and hot water. Hard to tell if this is the correct answer.
Aug 01, 2009 | Whirlpool LEQ9858L Electric Dryer
Lg dlg2524w runs and tries to heat but doesn't
Our electric did the same thing...techie guy said it was working fine, suggested I clear the dryer lint vent pipe which I tried but it was destroyed so I had to rebuild the whole line which took a day of messing around with the wall behind the unit, the ceiling exit hole and in the attic some. But Man!! it works great now!! All that heat and moist air has to go somewhere away from the machine, or it just goes back into your clothes. Super important. Good luck!
Mar 25, 2009 | LG DLG5932W Gas Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Re: 2 yr old GE Electrictric with poorheat
Vent lines that run through an attic are the worst. I still don't understand why builders install them in homes like this. To answer your question, "Yes" it is possible for the vent line to be clogged in only 2 years. When the dryer is running, the vent line is a mixture of lint, hot air, and moisture from your clothes. Over a period of time with restricted air flow, the vent line interior can become moist from condensation and lint will begin to collect and stick. In a configuration such as yours, you also have gravity working against you. Typically, what happens is the lint collects, can't be pushed out, and will fall down inside the vent line in the wall. Most manufacturers recommend inspecting your ventilation at least once per YEAR. Two years is an awful long time to go without inspecting your vent lines. Not to mention this can become a fire hazard and/or a habitat for rodents (mice love dryer lint to build nests). I would recommend once in the fall and once in the spring. It doesn't take long for accumulations of lint to form and clog your exhaust.
"Yes", I would recommend trying to run your dryer with the exhaust hose removed to see if it works better. This is the easiest way to determine if you have an internal clog or external clog, or no clog at all. I would not run your dryer on a permanent basis like this, however, as it will heat up your home and add unecessary humidity as well.
As far as the element is concerned, if the dryer IS heating, I wouldn't recommend checking the element just yet. Heat usually indicates the element is actually turning on. Elements don't usually get weak, they simply burn out. If you had NO HEAT, then I would suggest checking the heating element.
Do the simple vent test that I suggested and let me know what you find. Then, we'll take it from there.
PS Rule of Thumb: The SHORTER and STRAIGHTER the dryer vent exhaust, the BETTER.
Sep 04, 2008 | Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
