Only get sound with high def program
Im using Dish network with HDMI cable but can only get sound on High def programing. using the RX-V565
    Sergeant:
    Champion:
  • 232 Answers
Your reciever only recongnise the HD sound due to the cable you are using .
if you use other output , you will loose a bit of sound quality but will be able you to lesting to all sounds .
Posted on Sep 28, 2009
I cant connect my dish satalite to my ILO telivision, should it be connected to the ATV port or the DTV port.
If you satellite is HD don't connect it to either port, Use an HDMI or component (5 wire cable) so as to receive high def signals. If you must uase channel 3, You want the ATV input. On channel 3 YOU WILL NOT RECEIVE HD PROGRAMMING> check your hookup guide from Dish network.
Jul 09, 2011 | iLO Televison & Video
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
How do I hookup LHT854 Theater System to tv if using comcast digital box? DVD player works fine with sound but but no sound if trying to watch tv.
most cable companies will provide you a high def. cable box for no additional cost. swap digital for high def box. run dvd into high def cable box and run hdmi output from cable box to lg input. hope this helps
Feb 01, 2010 | LG LHT854 Theater System
Sounds stop working after about 1 to 2 hours of viewing.
We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Jan 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Oct 30, 2008 | JVC TH-M505 System
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
 Grubhead
Grubhead
