I rebooted my ruby register and i found that my report menu under system setup is missing..? what should i do now..?
  • dancruz_143 Sep 28, 2009
    how till i get in to contact with verifone tech and ask for backdoor password..?
    and what is backdoor password exactly means..?
    President:
  • 1,462 Answers
Menus appearing and disapperaing is based on the security.
Your menus can appear and disappear with your security level on how you are signing in ...
You might need a backdoor password from a verifone tech that will give all menus and access.
Without this password, immediately after restarting some of your menu will disappear.
Please leave me comment,if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 28, 2009
  • Vinod Kumar
    Vinod Kumar Sep 28, 2009
    It s a password which has administrative level of allowing accss to Ruby content,
    This password is requires you to access all the administrative content, such as enabling and disabling menus etc..
    RNJ VINODKUMAR
Should a beginner use RubyMine for Ruby on Rails development?
We work on Ruby on Rails professionally for many years and loved.
Ruby on Rails knows, really well
For beginners, then main advantages are that it:
  • reports syntax errors (better than any other tool I've used)
  • color codes local variables separately from method calls
  • jumps to source code very accurately (CMD+ Click on mac)
  • highlights common code style issues
  • has amazing rename variable / method tools that differentiate between method calls and local variables, understand Ruby scope etc...
  • shows you your gems right along with your source code, in case you want to see what's happening under the hood
allows you to run ruby files from within Ruby on Rails, minimizing windows / tabbing around different apps
For more details, visit us:http://www.rubyonrail.net
Ruby on Rails development company in USA Hire Ruby on Rails Developer
Feb 13, 2017 | Ruby Computers & Internet
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
My ruby register asking me the system no registered. So how can I register my register.
Registration works once.
1. If you are trying it for first time, contact vendor.
2. If you have installed it elsewhere, uninstall it first.
Oct 26, 2014 | Computers & Internet
Casio te 2400 How to download Z tape to Compact Flash Card
Found this on another website. I have not tried it to verify, but it sounds reasonable:
http://www.baystatepos.com/CasioTE-2400spec.html
Insert a CF FLASH CARD into the front of the register before taking a "Z" report. Turn the manager's key to Z1 and press CASH AMOUNT TENDER to issue a BATCH report of all sales activity, which prints from the register's receipt printer. This report information is also automatically written to the CF Flash Card capturing the register's terminal number and date of the report. This data is formatted as a "TXT" file and can be open with Microsoft EXCEL. Use EXCEL to combine multiple register totals. Create historical report data and e-mail the reports to corporate or to district managers. Saves time and reduces transposition errors.
Use the CF Flash Card to save the entire register program before moving the register to a new venue where it can be reprogrammed in a flash with the new menu.
Apr 11, 2013 | Casio TE-2400 Electronic Cash Register
The printer cannot recognize the ink
What should I do if the printer will not recognize the cartridge after refilling?
  • Turn on the printer and remove both cartridges
  • Place both cartridges in front of you so that you can see the contact foil, with the nozzles facing downwards
  • With adhesive tape, cover the FOUR upper contact points on the far left contact column of both cartridges
  • Reinsert the two cartridges and close the cover
  • Open the cover again after 2 or 3 seconds
  • Wait until the printer gives you the cartridge carriage (If there seems to be a problem with either of the cartridges, ignore it)
  • Open the cover and remove the two cartridges
  • Remove the adhesive tape
  • Clean the contacts, reinsert the cartridges and close the cover.
  • Most imp.
    If you refill your cartridges more then 3 times,then it is expired and that's why it is not displayed in your printer.For this,you have to go for ma new cartridge.
    or some these steps
  • Try below steps.May be it will helpful.
    1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
    2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
    3. From the same menu I also ran "Clean Print Cartridges"
    4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
    5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Aug 09, 2010 | Computers & Internet
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution:Keyboard issue
OS Loader v4.01
Oct 01, 2009 | Microsoft Windows XP Professional
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
Unable to register cyberlink power dvd 6. reports no internet connection
When you first start your software, a registration dialog box will appear. All you have to do is submit your name and address to complete your registration.
If you have skipped that dialog, you can access it by the following steps (the following steps are based on Windows' Classic Start menu setup):
  • Click the Start menu of your computer,
  • select Programs,
  • select the CyberLink Product, and
  • then click Online registration
The same online registration interface appears. Submit your name, address and then click Register Now.
alfeild said-reports no internet connection-
is this on your connection or when you try to register your product.cyberlink.?
riz.
Aug 20, 2008 | Computers & Internet
Gemstone Ruby Supersystem missing Report from Menu
Your menus can appear and disappear with your security level on how you are signing in ... You might need a backdoor password from a verifone tech that will give all menus and access...  Thanks  Steve at myworldonline dot com
Dec 02, 2007 | Computers & Internet
Computers & Internet Logo
287 people viewed this question
David Payne
David Payne
