Question about Dell Latitude D510 Notebook
Dell latitude d510 new battery wont charge
Hi, I just replace my Dell D510's battery with a new one but when I plug in the charger it won't charge it. I used another dell charger from a newer inspiron and it worked, i was wondering if this has to do something with my charger and if there is a fix for this or do i have to get a new charger?
    Problem Solver:
  • 14 Answers
The laptop charger is the problem, try to fix it if you can or buy a new one with warranty..
Posted on Sep 28, 2009
3 Suggested Answers
  • 341 Answers
SOURCE: Dell Latitude D510 video card doesn't support texture acceleratio
I doubt it very much. laptop videocards are usually part of the motherboard, so unless you want to do that...
Also, take into account that, although you can play games in a laptop computer, their video performance is usually very poor. They are not designed for heavy gaming
Posted on Mar 19, 2010
  • 178 Answers
SOURCE: i'm trying to plug into my dell latitude d510 to m...
It may be some drive or enternet setting problem of your dell latitude d510 battery .
Posted on May 31, 2010
My dell latitude d510 is not charging and i the icon is not on it
Take the battery out and wait a few minutes. Then place it back in and see if the light to the battery charging indicator goes on.
Check the plug that goes into the laptop from the charger. Look to see if it's frayed or has exposed parts. My need a new charger.
Aug 23, 2013 | Dell Inspiron 1501 Notebook
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
My dell latitude d510 cpu fan won't start when i turn it on
sound like a faulty fan or the fan's power lead check all connections soldering and plugs for secure dust free connections or replace the fan
hope this helps
Oct 09, 2012 | Dell Latitude D510 Notebook
I have a dell latitude d510 pink no power but charger brand new can u help
Check the fuse in the plug?
See if anyone else has the same charger/pc and try theirs with your pc/charger to rule out one.
My daughter had a similar problem, after ordering a new charger and still not working, she found out the battery was upside down !!, now it works ;)
Jul 08, 2012 | Dell Latitude D510 Notebook
I was using my dell latitude d510 just fine the other day the only thing that was wrong is the battery wont charge so it always had to be plugged in. well from using the charger so much it finally stop...
The problem could be with the port the cord connects too. It could also be with the battery. If you take the battery out, and you still can't run on AC power, you need to replace the port. Take it to a computer/hardware shop and have it done.
Feb 24, 2011 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
May 05, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Jan 20, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 Notebook Logo
596 people viewed this question
Alun Cox
