Question about Samsung (MP0804H) 80 GB Hard Drive
Samsung MP0804h I cannot boot my samsung MP0804h external hard to my computer
  • 55 Answers
You dont say what you've tried already. Have you used the add hardware wizard in control panel.? Have you checked your BIOS settings to see if enabled & computer can see it.? Tap delete key during initial power up of computer is usual route in.
Posted on Sep 28, 2009
My Samsung MP0804H HD is not responding. I have connected to my laptop (windows vista) It is getting detected and I can view the folders. But when I click on any folder, it is not responding...
click start control panel scroll to folder options this may vary depending on your operating system place a tick in the single click to open a folder option or if you right click on the drive/folder select properties there will be an array of options in the security tab make sure you have full control
click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control be the computers "administrator"
hope this helps
Apr 17, 2011 | Samsung (MP0804H) 80 GB Hard Drive
My samsung harddisk is so noisy making noise..... and when i conected that to ma pc pc is not going to boot
Hello their sam4ubabe
So you mean you Took it off and put it back again...
Try this sequence:..
1. Remove your Hard disk
2. Clean it, remove Dust particles around the connectors
3. Put back the Hard disk, don't tight it so much.
4. Put back those Connectors from Hard disk connectors and Power Connectors.
5. Push the connectors to tighten contacts.
Power it ON.
Lets see if it goes back.
-dontput
Aug 17, 2010 | Samsung (MP0804H) 80 GB Hard Drive
Not showen in computer
you need to properly re partition the hard drive
try c: max size
May 26, 2010 | Samsung (MP0804H) 80 GB Hard Drive
Samsung MP0804H not working
Try the had disc on a different computer and if it works hen ok..... otherwise ........... sorry................ If the hard disc is working then use windows Xp SP2.
Apr 14, 2009 | Computers & Internet
Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
Feb 02, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Jan 29, 2009 | Samsung (MP0804H) 80 GB Hard Drive
See only one of four partitiona in a mobile disk
Go into the control panel.
Go to administrtive tools.
Go to Computer management.
Click on disk management on the left side of the screen.
Click on the drive you partitioned.
Does it show four partions?
Were they partitioned as NTFS or a different format?
Jul 16, 2008 | Samsung (MP0804H) 80 GB Hard Drive
Samsung 80 GB IDE
hi, sounds like a faulty hard drive i would suggest downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/ even though the test software is for seagate it still works for all drivers.
boot from the floppy disk it creates and it will test the drive..
Happy New Year
John
Dec 28, 2007 | Samsung (MP0804H) 80 GB Hard Drive
PC not recognising the slave drive
Assuming you set it as slave or cable select as required by the motherboard, you have to first get the bios to recognise it press F2 or Del on boot up to enter cmos and then there should be an option to auto detect drives, save settings for a re boot. When in windows, right click on my computer icon and select manage>disk management and then your drives will be listed, right click on the slave drive and select format or set as active and it will then show, but only 137GB may show depending on the bios version.
Oct 03, 2007 | Samsung (MP0804H) 80 GB Hard Drive
Samsung (MP0804H) 80 GB Hard Drive Logo
422 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
