Question about RIM BlackBerry? Tour 9630 Smartphone
App error 523 on blackberry tour
Also, right before it flashes to the app error 523 screen, it loads up like everything is fine and then a messages pops up: uncaught exception - java lang nullpointer exception.
App eror 523 for Blackberry Tour
Posted on Nov 28, 2009
App 523 error reset
1) Make sure you have Blackberry Desktop Manager installed.
http://na.blackberry.com/eng/services/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life. Congrats! Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
Additional information:
http://www.blackberry.com/btsc/KB24395 "Error 523", "App Error 523", or "JVM 523" appears on the BlackBerry smartphone
Article ID: http://www.blackberry.com/btsc/KB10144
KB10144 How to force the detection of the BlackBerry smartphone using Application Loader
I got that from: http://supportforums.blackberry.com/t5/BlackBerry-Curve/App-error-523-reset/td-p/1743575
Mar 23, 2014 | RIM Blackberry 8310 8320 8330 Curve 8100...
App error 523 reset
you should reload its firmware. download and install blackberry desktop manager the latest for your handset and re-load firmware. make sure you have a good internet connection.
Mar 01, 2011 | RIM BlackBerry? Tour 9630 Smartphone
I have a blackberry storm. When I woke up this morning, I found an App Error 523 Reset on a white screen. When I pushed the reset button, my phone loaded, but then it said Uncaught Exception 8>=8 and...
HI,
I suggest the following steps (insert plenty of reboots of your PC...not just restarts, but full power down reboots). Also, it is advised that you be logged into the PC on an account with full admin rights. Further, under Vista, use the "Run As Administrator" option for everything. If you have never installed the Desktop Software to your PC, then skip steps 1 and 2.
1) Remove your device OS update package from your PC (add/remove programs)
2) Cleanly uninstall the RIM DTM software:
  • KB02206 How to perform a clean uninstall of BlackBerry Desktop Software
3) Get a fresh download of the RIM DTM software:
  • Choose the version that is newest and (if applicable) compatible with your PIM (if you are synchornizing via USB):
  • KB12268 Applications supported by BlackBerry Desktop Manager for synchronization
4) Download (to your PC) a fresh copy of your device OS package from your carrier:
5) Install DTM to your PC
6) Install (also to your PC), the device OS package
OK...next, follow this KB (including the other links within the KB) for recovery from the 523 error:
  • KB11816 Error "523 app.error.Reset" appears on the BlackBerry smartphone
Good luck and let us know!
Jun 22, 2010 | RIM BlackBerry Storm 9530 Smartphone
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
I have a blackberry 8130 and the app 523 error coming up how to fix it
On the BlackBerry smartphone, the following error message appears "app 523 error" after pressing the Mute button, accessing an application, or performing a hard reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Add/Remove Applications.
  4. Type your BlackBerry smartphone password and click OK.
  5. Select the check boxes next to the names of the applications you want to load.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Click OK.
  8. Click Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Jul 12, 2009 | RIM BlackBerry Pearl 8100
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
What does app error 523 mean and and how can i fix it?
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
Good Luck and do let me know
Feb 28, 2009 | RIM BlackBerry 7100G Smartphone
RIM BlackBerry? Tour 9630 Smartphone Logo
3,017 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
