Question about Hitachi CLU-5713TSI Remote Control
I want to set up my remote clu 5729tsi to the cable box
  • 403 Answers
Try this as all remotes work about the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 28, 2009
Top of Hitachi CLU-5729TSI screen is blue
Check all the input connections for firmness. Especially to its Ariel connection. If all is found OK, check and replace the tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2015 | Hitachi Televison & Video
How can I do a factory reset on a Hitachi clu-5729TSI
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 07, 2015 | Hitachi Televison & Video
Codes for a Hitachi remote CLU-4324UG
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 23, 2015 | Toshiba Televison & Video
How do i reprogram a Hitachi 60" remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
Oct 09, 2014 | Televison & Video
Is the hitachi clu-5727tsi remote capatible with sony televison
If it has set-up code to sony brand TVs, you can. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 19, 2014 | Hitachi CLU-5727TSI Remote Control HL01827
How to fix hitachi CLU-5729TSI
Refer its user manual for details.
Aug 01, 2014 | Televison & Video
How to program Hitachi CLU-5729TSI
Here is a link to the manual with component codes for this remote:
http://remotes.com/remotes/documents/Hitachi/CLU-5729TSI.pdf
Clu-5729tsi remote codes
CONTACT HITACHI TECH SUPPORT
Jan 11, 2014 | Hitachi Televison & Video
Need code for att uverse cable box
296,299,294. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Dec 31, 2013 | Hitachi CLU-4352UG2 Remote Control HL02073
I need to know how to program my CLU-5729TSI to run my Philips DVD player DVP1013
I have Hitachi universal remote CLU - 5729TSI how can I Program it to change the code for a different tv. a toshiba 36 inch it is around a 1999-2000 model.
Sep 27, 2009 | Hitachi CLU-5713TSI Remote Control
Hitachi CLU-5713TSI Remote Control Logo
1,372 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
