Question about Onkyo TX-SV525 Receiver
Went into protect mode... then no audio came out.. just sparks and smoke.. volume was on low.. just changed it to theather when it did it.
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
Amp powers up red then turns green for a few seconds then shuts off power alltogether
My specker was working fine then the am went to on protection mode and backs power mode but my specker doesnt work but on when my volume is low
Sep 23, 2011 | Kicker (ZX750.1) Car Audio Amplifier
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Dan
Mar 18, 2009 | Denon AVR-3600
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Sony Xplod Car Audio Amplifier
When the protect mode is activated,always be the audio amplifiers IC's damaged you gotta change them.
Jun 05, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
when you turn it on, hold the power button until it has fully loaded
Sep 02, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Sony XM-2002GTR Car Audio Amplifier
I don't think it is a problem. Your amp probably has a power-saving mode being activated at low volume levels. Actually I don't know exactly what your amp is, but this is just a guess, and it could be a plausible one as long as you can get sound without using the amp. If it is so, it must have a function to deactivate the power-saving mode.
Apr 19, 2007 | Sony XM-2002GTR Car Audio Amplifier
check your ground cable and make sure it is making a good connection because sometimes this does it
Apr 19, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
192 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
