Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub Zero 650 - Light doesn't go on
I used to be able to press the switch a few times and it miraculously went on... no longer the case. Any idea on how to fix? Could it be as simple as needing a new bulb?
  • 339 Answers
It's either a new bulb needed or a new door switch. Try the bulb first as it's cheaper.
Posted on Sep 28, 2009
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 650/s control board light is out and inside lights out but fridge works.
On this model, the lights work with the light switch, if it stick all the light in that section will not work. Parts number 7014646 (about 20 bucks) If only the control display is not illuminated then the bulb behind the control is the only problem.
I hope this helps.
Oct 02, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
The light in the refrigerator went out and now it is beeping when we open it..we got an estimate of $130 to repair....we wanted to see if we could possibly do it ourselves?
Dear ssala19,
I'm sorry to hear that the lights in your Sub-zero unit are not working. It is unlikely that all the bulbs went out at the same time. You most likely have a bad light switch. If you open the refrigerator door & look upwards you will see two white switches. The switch on the left controls the lights. The part number to this light switch is 7014646. We can supply you with light switch replacement instructions if you contact us directly. Make sure that you turn the unit off at the circuit breaker before changing the light switch.
To find a Factory Authorized Service Company in your area please use the link below. Enter your zip code, select 'Service, Repair and Parts', choose a mileage radius, and you will receive a listing of all Factory Authorized Service Companies that meet your requirements. A Regional Parts Distributor can also be found via this link if you would like to order the switch or bulbs.
http://www.subzero.com/locator
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Frozen vegtables within refrigerator (sub zero 650)
Replacing the light switch is not related to the temperature. Check the settings on your controls.
May 24, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
314 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
