Bosch Axxis WFL 2060 Front Load Washer
Problem for Bosch Axxis WFL 2060 Front Load Washer
Want to replace motor brushes...any tips on this
By tbryant9811 on Sep 28, 2009
Need to replace motor brushes...any tips on this job?
Comments:
Nov 03, 2009
- You can replace the brushes in the same amount of time you spend cleaning the commutator. I bought them at Appliance Parts Depot here in Mesa, AZ for $38.00 and installed them in less than a half hour. A local repair company wanted $65.00 for the brushes and one hour ($99.00) to install them. A 12 year old could do this job. Just unplug lead from brush, gently bend only two retaining tangs (there are four) and the brushes pop right out. I then cleaned the commutator and reassembled. I did have some interesting noises the first load or two while the brushes seated in. My machine is 7 years old and the old brushes were completely used up. Hope this helps...don't be afraid to try this, it's simple. The motor comes out easily.
Solution #1
posted on Nov 02, 2009
Not Rated)
mgchater
Rank: Apprentice
Rating: 0%, 0 votes
I need to also, so please post what you learn. I found several examples for other WMs on YouTube (search brushes carbon washing machine) Note, I was able to get my Bosch Axxis WFL 2060 spin working again with the following quick carbon dust cleaning trick:
1) Unplug WM and tip up to a 45 degree angle and then safely stabilize so you can safely access motor from bottom. No need to take off back or disconnect motor.
2) Using a small tool like a 1/4 allen wrench or medium screwdriver start tapping repeatedly (for 2 mins) on the brush holders, and back metal clips that connect to the brushes, your just moving the dust around really.
3) Next using an alcohol damp cloth clean the motor commutator - on this motor it is easily exposed on one of the sides 90 degrees away from, and in line with brush holders. Hold cloth on commutator and turn motor, this will also make it clear if commutator is damaged. You cloth should be pretty dirt after 2-3 rotations.
Repeat 2 and 3 above a few more times cleaning up all the carbon dust off the commutator and around the brushes.
After that tip down and test again. A more thorough cleaning could be done by removing brushes and cleaning em - but this will buy you a few weeks/months of operation.
Was this helpful?
Yes
No
Popular Solutions for Bosch Axxis WFL 2060 Front
Questions and Unsolved Problems for Bosch Axxis WFL 2060 Front
Do you recommend Bosch Axxis WFL 2060 Front Load Washer?
Answer
Answer
drum does not turn. motor appears to be working
Answer
Is there a way to stop the beep on my washing after a cycle completes?
Answer
tear in the gasket, rust under the lip, not sure whether to grind off the rust and repaint or... (More)
Answer
what do the symbols (* or l, ll )on the detergent dispenser mean?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Axxis WFL 2060 Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
