Question about Ultra Car Video Players
Setting clock how do you set the clock on the sansui XR- 665USB/MP3 automotive mp3 player
0 characters
1 Points
How do you set the clock
on tho screen you have settings, open it and then, clock adjustment.
Sep 27, 2012 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
How do i set the clock on my IVA-w200 apline deck
you can download the manual from here, explains the procedure to set the clock
hope it helps
Apr 07, 2010 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
I cant set the clock "? i wanna solve for this prop
Try going to map mode the go to menu and click on function or setting and clock
Mar 07, 2009 | Pioneer AVIC-D3 Car DVD Player
Car dvd players
sory I did not see that this system will play external vieod, it looks like soumd only not video.
her is a list of specs you ca see for your self.
hope this helps you.
N-CITY DVD-393 In-Dash Car
DVD/VCD/CD/CDRW/MP3/WMA/MP4 Player with Digital
Slot for USB/MMC/SD Memory playback
The New DVD 300 series from N-CITY comes with
everything you expect
Fully featured with Digital Media Slot for
DIVX Playback, Sub-Woofer output & smart resume function
��. Support USB & MMC/SD Memory Card for direct playback
��.Big size Dot matrix Display
��.DVD/DVD-R+/DIVX/VCD/MP3/ WMA/MP4/CD-RW Compatible
��.Fold Down Detacheble Front Panel
��.MP3 Selection by Sequence Number & Track Name, ID Display
��.Encoder Volume Control
��.Super Electronic Anti-Shock
��.Preset EQ (Flat/Pop/Rock/Classic)
��.AM/FM/MPX PLL Tuning Stereo Receiver
��.30 Memories System (FM18/AM12)
��.Auto Memory Store
��.Repeat/Program/Random/Intro Play
��.Electronic Audio Control
��.8-Times Oversampling
��.Mute / Loud Control / Clock
��.Auto Loading and Ejecting
��. 1- Bit D/A Converter
��. RCA Preamp Output
��. Subwoofer Output
��.ISO Mouting Chasis
��. 4 Channels Output (2V Preout)
��.60W X 4 Power Output
��.Full Function Remote Control
Jan 13, 2009 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
Clock setting on alpine iva-w200
Copied from support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Problem with playing DVD-R discs
The problem is that the mp3 format compresses the files to make them very small. The advance function on the dvd player was set up to advance, let's say, 1/2 second at a time. Well, the dvd or cd file will advance a 1/2 second, but an mp3 format file, which is way smaller, will advance the same distance on the disc which ends up being 10 seconds or so. I had the same problem with my panasonic. Solution would be to burn the files onto the disc in a cd format. You won't be able to put 100+ songs on the disc like you could with an mp3 format, but you will be able to controll the advancing a lot easier.
Oct 18, 2007 | Panasonic CQ-VD7001U Car DVD Player
AUDIOVOX CDA 100 AM/FM/CD setting clock
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Car Video Players Logo
Top Ultra Car Video Players Experts
xxxxxx xxx
Are you an Ultra Car Video Player Expert? Answer questions, earn points and help others
