Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Ice maker makes ticking sound as it makes ice..seems loud... is this normal??
  • 80 Answers
Yes this is normal operation of the timmer.
John
Posted on Sep 28, 2009
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
Very Loud Ice Maker in GE gfss6kkxs Fridge
Sorry to inform you but GE refrigerators are known for their noise making machines. I myself have a GE Profile side by side but will never own another GE product. After repairing appliances GE is better priced than their competition and the reason cheaper made product. Sometimes cheaper doesn't mean better. Outside looks really good but what you don't see is ugly. BB
Jan 20, 2010 | GE Refrigerators
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Ice maker "ticking" sound?
Mine started doing the same thing. The problem with mine was that the part that spins around to eject the ice is hung up... first, it was trapping an ice cube in it... I cleared the cube and it stopped making noise for a while, then a cube hung up again. Now I found that one of the 'teeth,' all the way to the right, was stuck under the housing... the part is bent, and needs to be replaced.
Check the part that spins to make sure nothing is stuck. Service is expected in home soon (I hope).
Jul 05, 2008 | LG LRFD25850 French Door Refrigerator
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
113 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
