Question about Pantech Matrix Cell Phone
The charger goes into the port, but the phone does not recognize that a charger is attached to the phone and therefore does not charge the battery?
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
The cable is plugged in but my phone wont charge
It can be deduced that the charging port of your phone which carries power from the charger to the panel in no more functioning,therefore the phone is unable to charge,
But,before we conclude that the problem is from the charging port,i will suggest you test the charger with another phone of its kind,if the charger charges the phone,it can be concluded that the problem is from the charging port,and the solution is to replace the charging port,
However, if it doesn't charge the other phone ,it means the problem is from the charger,which indicates that you have to get another charger instead of changing the charging port of your phone.
Thanks and take care.
Aug 21, 2010 | Cell Phones
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
I have the Verizon LGVX8350R phone, it works perfectly but the only thing is that it will NOT charge, I just bought a new charger from walmart 3 weeks ago so its brand new. I did drop the phone on a...
Hi, you will have to test for both to be sure which is faulty.
You can use another charger to test if it will charge or you can use the charger on another Verizon phone to check if the charger is working.
After that, if the charger works, that means the charging port that you attach the charger to the phone will be the problem.
You will need to replace the charging port.
Take care.
Jun 22, 2010 | LG VX8350 Cellular Phone
Phone will not charge with wall charger
have you tried it with another charger car charger or home to see if it is just that charger or if it is the battery or the port if you hook it to another charger and it doesnt recognize the connection and say charging its the port and you will need a replacement if it is recognizing it but the battery wont charge and its doing the same thing its the battery or it will work fine and then its just the charger depending on what insurance you have and how long you have had it the retail store may be able to warranty the charger they never warranty batteries and they run 49.99 generally that model is old you will probably have to get it some where else i doubt they still carry it try amazon.com or overstock.com or ebay best places for cheap cell batteries for your model they run about 9.99 never go to verizon for a new battery they are way overrated
Jun 05, 2010 | Palm Treo 650 Handheld
Chager not supported problems
The problem is either from the phone charger, the charging port, the battery, or the phone board.
Therefore, try charging the phone with another battery and charger.
If problem persists after doing as I said, then I would advice that you take the phone to a specialist.
Best wishes.
Dec 18, 2009 | Nokia 3110 Cellular Phone
Motorola W315
(If you are charging you phone inside your house) First make sure you have power to the receptacle you are using. test this by plugging in a lamp or radio into the receptacle you will be using.
I own the same phone and I have found that the phone has a small rubber cover that goes over the charging port. It's hinged but I found that it has to be removed in order to charge it because the charger can't connect securely with the rubber cover on the phone.
(If your are using a mobile charger) I have observed that my phone has a short in the mobile charger also and changes the ring tone after I charge it. My phone rings 1/2 of the time and I have found that this is a fault of the mobile phone charger. It charges the phone w/o any problem but the connection from the mobile charger is loose. This shorts out something inside the phone and changes my ring tone automatically.
Feb 11, 2008 | Motorola Mobility W315 Cellular Phone
Pantech Matrix  Cell Phone Logo
20 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
