Question about Toro Lawn Mower With Toro Power Tools
Motor does not run at speed it should and eventually stalls
  • 80 Answers
Check to see that your choke is coming off and that your air filter is clean.
John
Posted on Sep 28, 2009
Proton savvy 1.2 runs for a while then stalls
hi,
savvy engine is same with renault engine. there's a flywheel sensor/engine speed sensor between engine and gearbox. change the engine speed sensor.
The engine speed sensor is control the ignition timing, if the sensor can't read the 0' angle the engine won't fire up.
Jul 10, 2014 | 2009 Proton Savvy 1.2
1993 cavalier engine stalls.
Start checking and eventually replacing air filter, spark plugs, and fuel filter, check that air intake is not obstructed.
Oct 12, 2008 | 1993 Chevrolet Cavalier
Start and stall problems on a
Have you checked fuel filter and pump?
Jun 15, 2012 | Cars & Trucks
After my 94 plymouth voyager 3.0L gets to runnig temp it misfires and stalls once in gear.It runs fine when its cold. I did a tune-up and still have the same problem
Have fuel pressure checked when it starts to misfire/stall and driving down the road at normal speeds.
Not unusual for fuel pump to run at proper pressure when cool, but lose pressure when warmed up. If it's only running bad when off accelerator and stopping or turning and runs down the highway good, remove and clean AIS/IAC motor. ( idle speed motor ) Once cleaned, if it runs better for a while then starts to act up again, replace it.
Jul 16, 2011 | Plymouth Voyager Cars & Trucks
Have 1991 k1500 that idles rough; slows almost to stall, then speeds up, but eventually stalls, stalls when put into gear.
Does the truck stay running when you depress the gas pedal slightly? If so I would maybe suggest checking the IAC or idle air controller. In some cases they can be cleaned however most cases they need to be replaced. Not sure if this is your problem, but it is a place to start.
Dec 24, 2009 | 1991 Chevrolet K1500
Speed Queen Model SWT220WA 3/4 filled with water, loud buzzing sound, stopped.
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
Aug 28, 2009 | Speed Queen SWT921 Top Load Washer
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Truck loops during idle and eventually stalls.
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Apr 07, 2009 | 2001 Ford Explorer Sport
Engine idle
dirty intake throttle valve and air bypass idle speed control motor. ttry the following.
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 15, 2009 | 1985 Pontiac Fiero
Toro Lawn Mower With Toro Power Tools Logo
101 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
