Question about Cameras
Flash disabled The flash menu on one of the touchscreen models has only one option available: "no flash."
SOURCE: I bought a Sunpak 383
genius cam nb 100
Posted on Mar 09, 2008
SOURCE: Flash stopped working
I had the same problem, "BBWS" found this "solution":
Turn the camera on as if to take photos (not to review photos).
Press "Home" (upper left corner)
Press the camera tab (bottom left-most tab)
Press "Scene Selection (SCN)"
Press "OK" at the "Select type of scene" prompt
However, I still don't have flash available in the PGM or AUTO modes, which tells me it is still broken.
Posted on Jul 13, 2008
Geekman
  • 32281 Answers
SOURCE: nikon coolpix 774 menu buttons don't work
Try resetting the camera back to the factory default setting.
Remove the battery, leave it for 1/2 + hour, insert the battery and configure date time etc.
If it doesn't work then you have faulty camera.
Posted on Dec 03, 2008
  • 4 Answers
SOURCE: Flash has stopped working on my Nikon D40
There's a common problem in the flash arm. I found this link that shows a simple repair. If you use this and make the repair yourself, understand that you will void your warranty if you have one. Also, do not touch the bulb as you'll get oil on it, and don't touch the solder points on the wiring, you'll get zapped. http://www.vimeo.com/3141400
Posted on Nov 22, 2009
SOURCE: Can't turn the flash on...
check that you do not have the setting on burst as it will not be able to flash in this mode. when looking atthe screen about to take a photo, select menu, the first thingthat comes up is the mode, if it is in burst change in to normal and your camera should now have the option for flash or auto again :) good luck
Posted on Mar 28, 2010
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Built-in flash does not work even in a MASP mode
This often depends on the shooting mode you are using. It is often on a selection wheel. Say you are in Fireworks mode the flash will not fire. If you get out of a special mode back into normal camera I am pretty sure your flash will not be greyed out.
Jul 20, 2017 | Nikon D3100 Digital Camera
Flash problem
Whats the flash problem your encountering?
If flash is not currently on, or your trying to disable it. Go to the (Ok/Menu) button next to the (Monitor) button the back of your device. Follow the menu to the flash options to configure your setting.
Here is a owners manual to your device if you do not have one.
http://safemanuals.com/314159.php?k=9c6db366bb96cd5e51380712e3766822&ID=389390&q=OLYMPUS%20CAMEDIA%20C-120
Mar 06, 2011 | Olympus Camedia C-120 Digital Camera
My flash won't turn on! When I go to the flash icon to turn it on, the flash option isn't even there!
Mine was doing the same thing but I noticed (after playing around with it for a while) that I had the "REC Mode" on BURST and not NORMAL. When I set it back to NORMAL the FLASH options returned. Select MENU on the main display and the first option will look like a picture frame or multiple picture frames. You want it to look like the single picture frame for the FLASH option to be available.
Feb 22, 2010 | Sony Cybershot DSC-T200 Digital Camera
Want to disable Touchscreen on Pansonic Toughbook. How?
You can go to BIOS and you have an option to Enable/Disbale touchscreen. But some models dont have this option and the touch screen cannot be disabled.
Regards,
Shrey
Dec 17, 2009 | Office Equipment & Supplies
When fitting a Canon 430EX flash to 450D,,light emits but flash doesnt fire, no flash in any mode.
Your camera may have been set to not fire external flash. Go to your menu, 5th tab. Near the bottom, there's an option for Flash Control. Select that. It should now show "Enable" or "Disable". Enable it.
Also "External Flash func. Setting" gives you more options for your 430EX.
Jan 25, 2009 | Canon EOS 450D Digital Camera
Heya I have problem for watching the vedios on youtube. I dont know how turn on the java ,and also have problem for installing the new version of adobe flash player.Dont know want to do. Can u help...
dear donya, Internet Explorer 7 To enable or disable Java:
  1. From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
  2. Click the Programs tab.
  3. Click Manage Add-ons.
  4. Highlight Java Plug-in.
  5. Under "Settings", click Disable.
  6. Click OK, and then OK again.
To enable or disable JavaScript:
  1. From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
    Click the Security tab.
  2. Click Custom Level... .
  3. Scroll to the "Scripting" section of the list. Click Disable or Enable.
  4. Close and restart your browser.
Internet Explorer 6 and earlier
  1. From the Tools menu, choose Internet Options... .
    in version 6, click Custom Level... .
    • Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
      JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
  2. Close and restart your browser.
download latest adobe flash player and install.
if u r using ie6, try to upgrade it ie7.
thanks,
Sep 25, 2008 | Computers & Internet
Jul 13, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Mar 09, 2008 | Olympus EVOLT E-500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
