Question about Whirlpool Duet GHW9150P Front Load Washer
Failure Code of F-28 and the door is stuck
We started a load of laundry and when I returned to put it in the dryer I found out that the cycle was not finished and the door lock was engaged. None of the buttons were responsive so I unplugged it and plugged it back in. The door was still locked so I removed the top cover and reached inside the front to the door lock and found a manual release. I removed the clothes and tried to run a normal cylce. It seemed as though it was going to work but the door locked again and it would not run. There are several lights on the front illuminated and it flashes a code of F-28, the repair manual I found simply says electrical failure. I have not found anything that helps to troubleshoot the problem, anyone know what F-28 is or what part it could be referring to?
  • 80 Answers
F-28 refers to a sensor that has gone bad.
You will need to call a service repair man.
John
Posted on Sep 28, 2009
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Can't open the door
If the door remains locked and will not open, there is a manual release you can use to open the door. The following link explains how:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
Sometimes using the manual release will correct a momentary door jam problem and return the washer to normal operation.
If the door continues to lock and not open, you may also try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes problems are experienced as a result of a momentary glitch in the operation program. Resetting the CCU can often correct most minor problems.
If you require further assistance, please post back and let me know. I hope this helps you.
Jun 09, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Does not dry my clothes well and only had it 28 days
check your filter[clean if dirty]-check & seeif your vent is plugged-check to see if the vent doors outside the house open when dryer is on -[also maybe proppeler might have become stuck or loose, it sounds like a plugged vent problem.
Dec 22, 2009 | Maytag MEDC400V Dryer
Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
347 people viewed this question
Dan Webster
Dan Webster
Sal De
