Question about Dynex DX-LCD32-09 LCD TV
Dynex DX-LCD32-09. tv was working fine, then out
Dynex DX-LCD32-09. tv was working fine, then out of nowhere the screen turns mostly white. very faint color, almost a negative type display
  • karenannburk Sep 28, 2009
    the power supply is good. I actually took the back off, disconnected the lvd cable from the tcon board (i think), then turned the tv on and the screen lit up black again. so now im not sure where this leaves me. what is the lcd controller board?
  • 2,323 Answers
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Posted on Sep 28, 2009
  • Jaime Hernandez Sep 28, 2009
    The T-con board is known as LCD controller as well. I've repaired a few of these LCDs with a T-con board failure but none with main board or power supply failures. I will post the board part numbers later on.
Child hit screen with ball replace screen or junk tv
Search Results
    [PDF]DX-LCD37-09-2 - Dynex Products
    www.dynexproducts.com/.../DX-LCD37-09-2_08-1430_ENGLISH_WE...
    Jan 15, 2008 - DX-LCD37-09-2 ... Connecting an antenna, cable TV, or satellite TV box . ..... Remember that children can become excited while .... Do not drop your TV or hitthe glass screen. If the screen breaks, be careful of broken glass.Missing: ball
    [PDF]DX-32L200A12 DX-37L200A12 DX-46L262A12 - Dynex
    www.dynexproducts.com/.../DX-32L200-37L200-46L262A12_11-1082...
    DX-46L262A12. USER GUIDE. DX-32L-37L-46L_11-1082_MAN_V2_EN.book Page 0 Tuesday, November 22, 2011 1:09 PM .... Using the on-screen menus . ..... CHILDSAFETY ... TV or hit, jolt, or press hard against the LCD panel. If.Missing: lcd37 ‎ball
Feb 03, 2016 | Dynex DX-LCD37 TV
My Dynex 1909 has no sound other than a white noise type otherwise all is fine
Hello
Your Dynex TVs electronic tuner has the fault. Replace it. It will look like a small steel box, to ehich antenna cable gets connected.
Feb 01, 2012 | Dynex DX-LCD19-09 19 in. LCD TV
I have a dynex flat screen model number dx-lcd32-09 it has a white transparent screen how do i fix or what do i need
This sounds like the TV has a good backlight but no video signal to the LCD. Additional diagnostics are needed to determine where the fault actually is. Most likely its the board but it could be the panel itself. You will need to track resistance between the parts and possibly the current as well to find the exact fault.
Some parts for the TV are available here: http://www.partstore.com/Model/Best+Buy+Company+Incorporated/Dynex/DXLCD3209.aspx . ShopJimmy.com may have parts from slightly used TVs of this model (QC and then damaged in shipping).
I hope this helps.
Jul 31, 2011 | Dynex DX-LCD32-09 LCD TV
My screen is grey/white and no picture
The LCD controller (T-Con board) or main board needs to be replace to fix the no video failure.
Check this link to find parts for your LCD.
May 22, 2010 | Dynex DX-LCD37 TV
No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
May 11, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex TV white screen of death..Getting thrown around by BB
If under the manufacturers warranty, contact the manufacturer.
Jun 13, 2017 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
Broke a brand new TV screen dynex dx lcd32 09 Does anyone know how to buy a replacement screen
Try ebay look up the model number on there useing advanced search you just might find one.. Good luck.
Apr 22, 2009 | Dynex DX-LCD32-09 LCD TV
White Screen on Dynex LCD
Please stop buying these cheap things.....your out of luck. Parts are not available for these cheap chinnese sets....Thank Bill Clinton. Anyway, sound like the tuner going out. But....you can't get a tuner...Sorry. Just try using a vcr or cable box on video input and change channels that way.
Jul 28, 2008 | Dynex DX-LCD37 TV
Dynex DX-LCD32-09 LCD TV Logo
1,924 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
