Question about Facebook Social Network
I need to be level 32 in restaurantcity did you know??
    Problem Solver:
I dont know what that means? I have been on facebook for quite some time with no problem
Posted on Sep 28, 2009
1965 buick skylark float level ajustment for 4.9l carburetor
The float level and float drop are both measured with the gasket in place. Having said that, here are the following measurements.
Float level is measured between the edge of the float seam and the formerly mentioned gasket. This measurement is 1/2" on a 2 bbl. and 1 21/64" on a 4 bbl. for the primary and 1 3/8" on the secondary.
The float drop is measured from the bottom edge of the float as it's hanging from the pivot, to the gasket.
The 2 bbl. is 1 29/32" and the 4 bbl. is 1 19/32" on the primary and 1 3/16" on the secondary.
These measurements and instructions come from a 1965 Chilton Auto Repair Manual as that's the only reference I have.
Hope this helps.
May 31, 2015 | Buick Skylark Cars & Trucks
The unit comes on works fine for about 20 minutes then shuts off automatically. Its never done this up until recently. thanks
Chavez - It may simply be a case of what humidity extraction level you have the unit set on. Once the unit extracts the humidity/moisture for the level it's set on, it shuts OFF. When the level rises again, it turns ON. Try lowering the level to 32-35%. I suspect it will run longer at that setting. However, it the humidity level in your house is not high, the unit is operating as it should.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
I cannot change the set point on my humidity control. It is at 70%. If I press the up arrow i get 2 beeps and no change. When I press the down arrow there is no response at all. Is there some sort of...
The problem is, your trying to raise the humidity level, not lowering. These work in reverse of what you may think. Lower the level (Arrow Down) to 32% and it will continue to run, but will draw more humidity out of the air and will not stop until the water collection bucket is full or the humidity level reaches 32% or you turn it OFF.
When you pushed the Arrow Up Button, it was already on 70%, that's as high as it will go. But that means, you're trying to maintain a 70% humidity level. If it's Summer where you are, I don't think that's what you want.
Jun 24, 2011 | Kenmore 54501 Dehumidifier
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
Astar 32 inch flat screen model LTV 32BG
The only way to salvage the TV will be by repairing the power supply to the component level, meaning you will have change the parts that failed on your power supply.
Is a common failure on power supplies modules.
Let me know if you need further assistance.
Jun 10, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Protron 32
It looks like the power supply failed on your TV. The failure rate is about 95% in the power module.
There aren't service parts available to swap the entire assembly, the only option now will be to fix the power supply to the component level.
Let me know if you need more assistance. You can write to my email address jah2mil@hotmail.com
May 08, 2008 | Protron PLTV-32 Television
Protron PLTV-32 32" LCD TV - AC Power Adapter
mine doing the same thang....what do we do
Mar 23, 2008 | Protron PLTV-32 Television
Temp and humidity levels are not correct
It sounds as if the temperature sensor probe is touching the cold coil inside. The sensor is located in the incoming airflow, in front of the cold coil. It must not touch the coil. This should be visible with the cover off. You can gently bent the sensor away fron the coil, 1/4-1/2" of clearance is plenty.
Jun 06, 2007 | Maytag M7DH45B2A Dehumidifier
Facebook Social Network Logo
15 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
