Question about HP OfficeJet 7410 All-In-One InkJet Printer
Carriage return error does not stop. - HP OfficeJet 7410 All-In-One InkJet Printer
    Sergeant:
    Champion:
  • 269 Answers
There is a piece of paper jammed.Follow clearing paper procedure.If there is no paper jam push the reset button
Posted on Sep 28, 2009
How do you fix error 03130031-2f26
Hi
The printer won't let you go into print mode because it has to initialize first. Part of that process is checking that the carriage is free to move. If it isn't, initialisation stops and returns an error, and the printer won't go beyond this. Make sure that there is no damage to the carriage and nothing obstructing its movement, and that's not something you can do pushing buttons.
There may be any number of reasons why the init would stop, a motor failure, a problem on the logic board itself. The final outcome could be that fixing requires a lab and a tech.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 22, 2014 | Canon imagePROGRAF iPF8000 Printer
I have a Smith Cornona Electra XT. It still turns on, but when I do turn it on, the carriage automatically goes back and forth non-stop and it's like you arre holding the return button down conti
Find the problem, some linkage is sticking and you have to trace it through. Spray with WD40, then when working spray with other light oil, cause WD40 does not stay. Most likely the carriage return release . Take bottom off and watch what it hits on the left side, Also the tab button locked down will do this.
Jun 16, 2017 | Smith Corona Electra Xt Portable...
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
Error E-0800 during Initialization - carriage not moving
There is a problem with the "carriage board".
Try unplugging the printer from the wall, wait a minute. plug back into the wall.
If error returns, you may have to replace the "carriage board" or the "main board".
Apr 29, 2011 | HP DesignJet 9000 InkJet Printer
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Inkjet Printer Forum
Dec 18, 2008 | Canon i80 InkJet Printer
21:10 error
Hi HotRoddy,
This is a Service station error. Check for obstructions in the service station on the right.
Turn on the printer in service mode by holding down the UP arrow and ENTER keys (simultaniously).
Enter Service Utilities, choose Unlock Carriage. Turn the printer off and move the carriage to
the center of the printer. Turn the printer back on. The carriage and service station should
return to their home positions.
If the error returns on power-on, the service station will probably need to be replaced.
Parts and diagrams can be found at partsurfer.hp.com.
Hope this post was usefull for you.
Thanks,
Robosoft.
Jan 04, 2008 | HP DeskJet 500c InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
