Question about Tally T2250 Matrix Printer
Tally T2250 Matrix Printer does not pull up paper to be printed
Printer cannot pull paper instead it gives a beeping error sound
    Novelist:
  • 169 Answers
I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
To do this;
  • Stop any prin jobs gong to the pritner
  • If the printer has data in its buffer, power the printer off and back on again to clear this data
  • Ensure the printer is OFFLINE
  • Press the SETUP button
  • Press the button under ADJUST
  • Press the button under PAPER WAY
  • Use button 2 or 3 to change this to TRACTOR 1
  • Press SET
  • Place the pritner ONLINE
You should be back in action, if not post the message you see on the printers LCD display.
Posted on Oct 02, 2009
In the middle of printing out 8x10 photos, it stopped picking up the photo paper. Makes a grinding sound twice, then beeps error.
Hello Lynell,
Unfortunately, printers only last for about 3 years or up to 5 years if it's a more expensive model. Try a Google search or YouTube search for DIY repairs on the model you own. You may find some helpful information on how to repair your printer. Or, it may be time to get a new one. If that's the case, see if Best Buy will give you a trade in price on something new. Best of luck!
Feb 25, 2015 | Office Equipment & Supplies
Tally t2250 printer showing error +0018
Please mention 2nd Line Error Code...
Jun 03, 2014 | Tally T2250 Matrix Printer
Paper jam display
Most printers have a lid in the back of the printer that you can pull out and then just pull the paper out from there. You can also see the paper jam if you pull the paper tray out and try to pull it out from there but pulling from the back of the printer is much more easier and convenient.
Hope this helps. If have the model and printer information I might be able to give you more information. Sometimes even a tiny bit of paper will give paper jam error so it is necessary to clear it completely.
Mar 09, 2013 | Lexmark X5470 All-In-One InkJet Printer
Tally 2250 gives error +0017
The error message given by the 2250 would be longer than given in the question. The whole error message gives an indication of what might be causing the problem. Some things you may wish to check include; Check the print head is free to move and is not jammed Check the carriage shaft is clean and free from any sort of lubricant Check the timing strip to ensure this is in possition and is not dirty or warn Check the paper path to ensure the paper is free to feed through the printer.
Dec 13, 2011 | Tally T2250 Matrix Printer
T2250 giving error in harware alarm code +0000ne-w81 000 000000002 - 4032
Check whether AGA Gear working Proper or not OR giving noise after power on printer
If AGA Gear not working proper insert the steel rod in AGA gear properly
Oct 27, 2010 | Tally T2250 Matrix Printer
Printer is not running while the power cord is ok.
Epson says....
Why is the printer beeping three times and the Paper Out light is on?
This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Q: Why is the printer beeping three times and the Paper Out light is on? A: This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Sep 30, 2009 | Epson LX-300 Matrix Printer
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
344 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
