Question about Weber Genesis E-310 Gas Grill
Hello! The igniter isn't catching on our Genesis.
Hello! The igniter isn't catching on our Genesis. We're used to hearing the little click-click-click as we depress the button, but right now we open the tank but nothing happens when we try to ignite. Is there something we should be troubleshooting, or is there a part that we need to replace? Thank you.
p.s. We had a fire in the grill a few weeks ago (a morsel caught on fire and fell into the fat tray), but we put it out quickly and did a full inspection to see if any critical parts might have been damaged, but did'nt see anything. We've used the grill since then without incident.
  • 80 Answers
The igniter will need to be replaced.
John
Posted on Sep 28, 2009
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
Tip
Is your Whirlpool or Kenmore front load washer not draining
<span>Hello.<br /><br />The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.<br />To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,<br /><br />Good luck,i hope this helps<br /><br />Gene</span>
on Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
I saw an 02 and then an S. the water does not drain and the door does not open. What should I do?
Hello.
Good luck,i hope this helps,
Gene
Aug 18, 2011 | Kenmore Elite 45986 Front Load Washer
Won't spin and drain
Hello.
Gene
The striker button won't light the grill but a match will. It is an older Genesis Silver approximately five years old.
If your piezzo ignitor is still sparking, but not lighting the burners, then you may have one of the following problems. 1) If you have a standard push button piezzo igniter or a rotary style igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. 2) The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. 3) It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. 4) Your burner may be clogged or rusted at the point where the ignitor sparks to light it. Clean the burner. 5) If your push button ignitor is not sparking at all, it may be stuck inside from being out in the weather. While pushing it, spray it with WD-40 to unstick it.
Hope this helps. Douglas
Aug 05, 2010 | Weber Genesis Silver C Grill
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
My grill will not ignite. I tried both ways. What could be wrong?I hear the gas but it wont start
Hello. It could be a bad igniter. Go to any hardware and get a lighter, like this BIC
http://www.grillwithbic.com/
If it lights this way, clean the igniter, if it still doesn't spark, replace the igniter. Joe
Mar 20, 2010 | Weber Genesis Silver A Grill
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Grill not lighting
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the push button igniter next to the burner control knobs on the front of your grill.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the grill has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck
May 11, 2009 | Weber Genesis E-310 Gas Grill
Weber Genesis E-310 Gas Grill Logo
403 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
