Question about Miele W310 Front Load Washer
Check drain light comes on & washer does not drain
    President:
  • 1,776 Answers
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Door its lock shows light code f21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Water will not drain. water is trying to drain out & comes out in front. Disposal & sink drain is clear.
There is a outlet hose. Disconnect it into a pale. See if anything comes out.
There are areas in the washer that can pick up debris and plugg.the hose at the bottum of the washer
Check the inside lower portion of the washer for debri
Mar 24, 2010 | Dishwashers
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
My maytag washer won't drain
Take off the front panel (Use a putty knife to press in the tabs near each upper corner where the top lid meets the front panel).
Check the wiring (esp. the ground) on the pump - it may be corroded or loose.
Tip the machine back to access the underside & check the motor-driven belt that drives the drum & the discharge pump - it may have broken or come off.
Check the discharge pump for blockage.
Dec 06, 2009 | Tecnik TKL9260 Front Load Washer
Miele W310 Front Load Washer Logo
272 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
