Question about Actiontec (GT704WG) Router
How to use verizon wireless router? - Actiontec (GT704WG) Router
  • NinaE May 11, 2010
    Details, please.
  • 615 Answers
You need the CD first to install it and set it up, when you insert the CD it will let give you instructions and it will setup your system automatically....let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 28, 2009
Actiontec GT704WGB from Verizon is working through Earthlink yet Verizon still thinks it is providing service and want to set up my "account"
Sounds like you have Verizon software on your computer. The router has nothing to do with that. Go into control panel > add remove programs and remove the Verizon software.
Feb 02, 2013 | Actiontec GT704WG Wireless Router...
How do i set up the belkin wireless router we have high speed internet thru verizon
Plug your Ethernet cable from Verizon in the router.Set up your Belkin with the CD and configure.
May 26, 2012 | Belkin Surf N300 Wireless N Router
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
I suspect that Verizon is degrading service to forcr users to mig
Anything is possible but it would take a lot of work to jam wireless signals. As a communications company, Verizon, if caught would be in hot water with the FCC. I have an idea. Are you able to change channels on your wireless and try it. Also, is there anyway you could try a different wireless router? If FIOS is coming in, there may be maintenance changes in the infrastructure that effect your internet performance.
Aug 14, 2009 | Westell Wirespeed VersaLink...
My wnr3500 router will not detect my usb760 modem
Hi, Well, this router will not work with usb modem. For 3g usb modem purchase MBR624GU. Make sure to check if ur usb modem is listed in the compatibility list. Hope this helps.
Aug 10, 2009 | NetGear RangeMax Premium Wireless-N...
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Wireless-G Linksys Router No Signal with Verizon Modem
The first thing I would recommend is to reset the router to its factory defaults. Then reconfigure it according to your Verizon settings.
There are a number of things you need to set, in order for the router to be able to talk to Verizon correctly. These things such as dns name servers, the ip address you connect to (whether it is static or dynamic), and things of this nature. They should have given you all of this information, and if they did not you will need to contact them first or you will not be successful in connecting.
To be more specific regarding the error message, I need to know the specific model you have as well as the version of the software.
If you need additional help just post another question here and it will notify me that you have.
Jun 19, 2008 | Linksys Wireless-G WRT54G Router
Routers
There are many new generation routers that you can use Verizon internet such as D-link DIR-45o, Kyocera KR1 and many more models. you can check the link so see how the product looks like http://www.kyocera-wireless.com/kr1-router/
Jun 19, 2008 | Linksys Wireless-G Broadband Router
Actiontec (GT704WG) Router Logo
139 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
