Odor in my home
When I return home after an absence of a few days, I notice a smell which I wouldn't consider as grossly foul, but chemical or even mechanical, if that makes sense! When I am at home it seems to almost diaappear. After short absences, I notice the odor but not as strong.
    President:
  • 1,187 Answers
There may be mildew on the condensor (the big radiator inside the attic) and/or the water drip tray underneath it may not be fully draining causing the odor.
Your senses get "used" to the odor. Your brain will mask it so that you will be able to sense other odors.
Replace the return air filter more often. clean the airway taht the filter covers. Spray Lysol will help temporarily.
You must check the condensor & water drip pan.
Posted on Sep 28, 2009
Tip
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
I have a kenmore elite slide in range. we notice the smell of gas
There could be a couple things that would cause your symptoms, I will do my best to try and explain each one.
First off I am assuming from your dialog that everything is cooking the same on the top and in the oven, the times are the same the flames on the top burners look or sound no different. If this is the case the repair outside would not have a direct bearing on a 'problem' but it could cause the odor. Here is why...
Natural gas has no odor a chemical called Mercaptan is added to the gas to make a leak easier to detect. The amount of Mercaptan is regulated closely so it all is consumed in the flame. If there is too much you will get an odor from the flame.
The Mercaptan can line the inside of the piping that feeds gas from the regulator to the range. Working on the pipes can break loose some residue that may have a stronger presence of odorant causing you to smell it for some time. It will eventually go away.
The second thing that could cause this odor is if you have done any remodeling in the home, paint fumes, stains, oils many other chemicals can mix with the gas and cause this Mercaptan to not be burned up all the way and create an odor.
I hope this helps
May 21, 2010 | Kenmore Kitchen Ranges
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet...
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 15, 2010 | Ovens
Chemical odor
This can be a result of chemical reaction in internal parts. If you notice it is faint the keep orange peels to get off the smell. It could be the freon. It is kind of like your a.c. in your car. It is the gas that makes it cold. You might have a leak. Thank you Sir, Have a nice day.
Sep 17, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice smells/tastes like chemicals
discard ice keep making it till it goes away(dont eat ice) if doesnt go away-further investigate!!! :)
Jul 06, 2009 | Hotpoint HSS25GFP Side by Side...
Cleaning a microwave before using
It's probably normal, but you might visit your dealer and check another one and even another model or brand to see if they have the same odor.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 15, 2008 | Salton Microwave Ovens
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
