Question about Toshiba Satellite A135-S4727 Notebook
I think my mobob is bad. I removed all hardware except screen, mobo, keyboard. NO wifi, NO harddrive, NO Ram, No DVD/CD. I remove all power, held down the power button for over a minute. Still does the same thing when starting. I hear the harddrive, BAAAARELY-as if it doesn't have enough power, NO LCD screen light, NONE. Scanning the internet, I keep coming up with a bad MOBO. nothing was spilled on it. It was left on the desk running, I went out, came home, it was dead. The only lights coming on are the "cord power attached" the "power blue lite" the battery will come on in "orange" if I leave it installed. The harddrive light never flickers.
  • 1 more comment
  • tmahn642 Sep 28, 2009
    I do have some tools and skill to replace a bad component on the mobo, I just wonder if its a common failed component that I can remove and replace? The exact model is Satelite A135-S4727, PSAD0U-0NF00P, SERIAL 67239856k. Where is the best place to buy a quality, fair priced motherboard? thank you.
    See what you can come up with on the mobo for purchase recommedation? what is the actual part number? I've been looking at the web sites you recommended one of them is not easy to navigate. I now have the unit tore down to the mobo, I'm going to power it up and do some checks with my volt meter, heck, I even got an infrared probe....look for hot spots. I'm thinking of sending it to one of those repair guys on ebay....$150 repair? Thanks for your help.
    Thank you for confirming my observations.
  • 1,068 Answers
Yes the mother board is bad! it most likely over heated and took it out. you have done everything you can do to test it unless you know how to test electronics and have the equipment to do so!
Posted on Sep 28, 2009
  • michael schultz
    michael schultz Sep 28, 2009
    wht model is it? i can locate you a mother board for you if you want it used!
    let me kow if you have any more question and i will be happy to answer them. good luck man.
  • michael schultz
    www.laptopking.com
    Motherboard.Pronto.com
    are the two guys i usually check first and also ebay. but if you can check the voltage coming out of the power supply then you can verify if it is the power supply part of board or the processor. kinda sounds like it is in the power supply board and the time it takes you to figure it out then find and buy the parts you could have replace the mother board.
    so if you are smart you will just locate the board and be done with it or start looking for another one because as you must have found out these are plagued with issues with there power supply's on the board and might be just buying a little time.
    sorry i didn't have a sure way tofix it but ith this model they are tough.
    let me know if you don't findit i have a local guy that usally takes care of me but no warrenty. that the only down fall but i can check him for you if you can'tfind one.
Motherboard booting problems...How do I solve?
Hi
Try to boot with 1 stick of ram then swap it with the other and try again. Next unplug the case front connections from the mobo header (pins). Draw a sketch where they all go so you don't forget. I'm talking about the power switch, reset SW, HDD LED etc. Also remove anything connected to the back panel printers etc. Also remove the mouse and keyboard. Carefully, momentarily short the pins that were connected to the power switch and note results.
If it still doesn't boot, remove all parts from the mobo except 1 Stick of RAM, graphics card, PSU, and of course CPU. Leave the mouse and keyboard unplugged. Try to boot by shorting the mobo pins again. If it doesn't boot it is most likely either the PSU or the mobo. It could also be the CPU or RAM but it is less likely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | EliteGroup RS482-M754 Motherboard
Computer starts up then within 5sec. turns back off. I think maybe motherboard and or processor bad. Where can I get replacements?
Ebay have loads of spares both new and second hand.
Check the ac adapter and battery first if you haven't already done than pls remove RAM and hard drive, what does it do now?
Jan 26, 2011 | E-Machines eMachines Desktop PC
E-machine w5243 won't power on. Replaced power supply, nothing. Any quick diagnosis? Should there be a light on the motherboard to tell me it's at least getting power?
Almost all mobo's have a light of some sort to indicate power. If you replaced the power supply, check the power cable itself for damage or possible shorts. Check your outlet to make sure it is working properly. If there is a light on the mobo, then remove all power connectors to the all the hardware, i.e. hard drive, CD/DVD, etc.. Then remove one of the RAM sticks and try to power it on. If that is a fail then remove the other one and try to power on. It won't power all the way up, but it will give you 2 beeps (depending on default settings) indicating it has no RAM. If this works then replace the RAM. Both sticks if you have 2. If there is not light on the mobo, then check to make sure that the power supply cables are in correctly and all the way. You should have a 28 pin connector and either an 8 pin or a 4 pin connector. Make sure both of these are hooked up correctly. If they are, then you mobo is probably fried. If there is a light and the RAM passes the check then plug the power in the CD/DVD and try to power up, if this fails then you need to replace your optical drive. If the optical drive passes then plug the power into the hard drive and try to power up, if it's a fail then the hard drive is bad, if it passes then plug in the rest of hardware one by one and repeat the process until you have checked all hardware. If all the hardware passes then the mobo is shot.
Jan 12, 2011 | E-Machines eMachines Desktop PC
I had two bad PC's One would not power up. Thought power supply. Took out identical power supply from the other bad PC. Still would not power up. I fiqured bad mother board. Put the power supply back into...
Ensure the power supply at the wall is good, ensure all plugs of power supply are plugged into Mobo, especially the CPU pwr supply if it has one. You really need to know 100% if the power supply you are using is good. If so and absolutely no boot. HDD activity then I would first suspect ram then CPU then mobo. Simply remove / replace ram, sometimes fixes them.
Nov 30, 2009 | Dell Dimension 2400 PC Desktop
Machine doesn't power up
Remove and reseat all memory, power and processor.
Check your power supply and if good check the board for bad Caps.
Sep 20, 2009 | Abit KV-85 Motherboard
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
Ccomponants will not power up
David,
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
MONITER PROBLEMS
There is are many things that can cause this, try the following:
  • Disconnect any extra items you may have hooked up, disconnect power connectors too (except mobo and fans) (HDs, CD/DVD drives, extra cards except the video card)
  • Remove all but one stick of ram, then rotate the ram in several slots, and swap out that chip with others if it doesn't boot yet (sometimes bad ram will cause your error)
  • Re-seat your CPU
  • after all this also reset your bios, this can be done by unplugging the computer from the wall and removing the battery from the bios, or on some boards there is a jumper to do this (See your manual)
I hope this helps.
Jan 21, 2009 | AOpen Slot 1 AX63 Pro (91.87810.611)...
Laptop does not take any mains power
Try clearing your CMOS. This is done by removing battery and mains power, lifting the speaker cover off and then look under the keyboard. Unscrew panel where keyboard ribbon enters, you should now see your RAM & BIOS chip. Disconnect ribbon next to BIOS chip and reconnect, that should clear your CMOS.
Dec 01, 2008 | Computers & Internet
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Toshiba Satellite A135-S4727 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
