Question about Dell 926 All-In-One InkJet Printer
Hi my printer coloured ink has run low, i wanted to make use to the black ink to prin,but nothg comes out from d print, could u advise? I have tried to set to balck and white already in the printing preferences setup. thks
  • rachel858 Sep 28, 2009
    I need to find solutions for my dell printer 926
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Inks
Hi, Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. Unless you have selected "print in black & white only" your printer will "mix" the coloured inks with the black, also check the printer options to ensure you are not using the photographic quality as this will use inks very rapidly. You need to consider a couple of things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Jul 09, 2009 | Epson Office Equipment & Supplies
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Black Printer cartridge
It will tell you the colour is low, regardless of the format in which you are printing. I don't believe Canon provide a way for you to disable this for their printer range, so you'll need to put in the new colour cartridge to get rid of this error. (you should however, be able to print whilst receiving this message)
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Oct 18, 2007 | Office Equipment & Supplies
Dell 926 All-In-One InkJet Printer Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
