Question about Citizen GSX 190 Matrix Printer
I don't have the start up disk, am i able to still connect it to my computer
  • 615 Answers
Matrices’ printers are old and you may not be able to get driver for it even if you have the desk, go to the web and search for a driver first when you get one downloaded to your computer and then connect your printer and see if the work…you may need only the driver for that to work, good luck....let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 28, 2009
Need a start up disk for samsung i85camera
You don't need any additional software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jul 30, 2012 | Samsung Cameras
Format harddrive
What OS are you using?
In Windows, go to the disk management utility and see if the disk is listed. (In Win 7, this is Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions.) For XP and Vista, the directions are similar but do differ a bit. Look at the bottom of the window, to see the list of disks. (Disk 0 is your main hard disk; do not reformat this by accident.)
Assuming the disc is correctly connected to the enclosure and is seen by the computer, you should see it listed as a removable drive. Note: you may need to change the USB port. The MX100 is an enclosure for 3.5" hard disks and needs the AC cord plugged in as well.
You may want to connect and turn on the enclosure when the computer is off, then turn it on. Then turn on the computer. This will hopefully allow the USB drivers to note the new device.
For the Mac OS, look for the Disk Utility.
If you still don't see the drive, check that the cover (and plugs) are completely seated. (Turn off the enclosure first.) Try the hard disk in another enclosure or a USB/SATA hard drive adapter. (If you have a desktop with a free SATA data port and power connector, try connecting the disk directly to the computer. (You need to determine if the enclosure is faulty or the disk itself is bad.)
I hope this helps. Please add a comment with your OS and if you see the disk in the disk management utility, if you need additional assistance.
(This enclosure will work with older versions of Windows, back to Win98Se. However, I don't believe all of those versions came with disc formatting utilities. In that case, you would need a third-party partitioning software (Partition Magic, Paragon Partition Manager). If this disk was in another computer and you want to save the data, try copying the data before reformatting. This may be easier to do with the USB/SATA adapter or the direct connection to the motherboard of a desktop.)
Apr 17, 2012 | Antec MX100 Aluminum Hard Drive Enc e
I have a gateway tablet m285e. The problem is, it boots up to a black screen. F8 does nothing, trying to use a boot disk does nothing. I connected another monitor to it and still black screen. It does...
If you connect to external monitor and don`t work
Try:
1.- Remove the memory module and clean the gold connectors
reseat the memory.
If continue don`t show image
Disassembly the laptop
Remove the processor
and reseat again
If don`t work, is your Chipset video
Maybe you can try fix the chipset video
look solutions like
http://www.youtube.com/watch?v=BLNReuT67p8
apply heat to Chipset video.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Gateway M285-E Notebook
I try to connect my altec lansing XT2 USB on my windows XP and I can't. Could you help me, because i don't have the cd instruction to install . Thank you Yoyo
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 18, 2011 | Altec Lansing Multimedia Computer Speakers
The boot manager has been wiped from my motherboard
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
http://technet.microsoft.com/en-us/library/bb491051.aspx
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
May 16, 2011 | Computers & Internet
Nesecito la aplicacion msvcrt.d11.
You can also try safe mode command prompt
After run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
If you can get the malware installed and ran in safe mode or connect
the drive to another computer and run it you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Apr 11, 2011 | Dell Inspiron 1525 Notebook
My dell Inspiron 1525 keeps stalling when loading and then I cannot do anything at all, as it freezes up.... I am typing this from my desktop I tried to system restore it...to no avail I tried to...
If you can get the malware installed and ran in safe mode you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Apr 02, 2011 | Dell Inspiron 1525 Notebook
I have a dell inspiron mini 10 and it will not load properly, i only get to the windows blue screen and it will not go to the password page it is freezing please help
Try all the above first
Mar 30, 2011 | Dell Inspiron Mini 10 Notebook
It turns on but no screen appears
I'm not saying this will work but try it... You can take the hard drive out and connect it to a PC computer via SATA/IDE as a second drive to see if it is recognized and run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
You can also run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
If you can't connect to another computer
Try to check your disk this way here is a link to explain using your installation windows disk
Start your computer press F11 start from the cdrom with disk in and press R for repair when prompt
If you can get the malware installed and ran in safe mode or connect the drive to another computer and run it you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Feb 15, 2011 | Dell Inspiron Mini 10 Notebook
Unable to restore system of dell mini 10
Feb 13, 2011 | Dell Inspiron Mini 10 Notebook
Citizen GSX 190 Matrix Printer Logo
61 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
