Question about Kitchen Ranges
Mice got in the oven insulation. Smelled terrible when oven was turned on. I pulled out the insulation, but I need to know if I can use regular insulation (pink fiberglass) to replace it or not.
    President:
  • 1,714 Answers
They use a special high temperature rated insulation. Call an appliance repair shop and ask them what they have.
Posted on Sep 28, 2009
I have a small, 4-burner gas stove; no wondow in the oven door. I think my stove had a mouse infestation. I think the insulation above the oven has mouse urine in it; I can smell it, although there is no...
It is common for mice to get into the oven box insulation and nest. I had this problem before and its not likely you'll be able to get rid of the odor without replacing the insulation. Another issue is any fecal matter the mice leave behind. This can become a health hazard (expecially in an appliance that you use to prepare food). I would recommend replacing the insulation. If the model oven is correct, the insulation can be purchased for around $20 at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number will depend upon your COMPLETE model number (located on a nameplate around the oven door opening, or lower drawer opening (if equipped). On some models, the model number will appear on the back of the operator console. The first three sites on the list include exploded view parts illustrations to assist you with locating and properly indentifying any parts you may need. The insulation for the Magic Chef 31000 series is listed under the "Body" parts list.
To replace the insulation on MOST ranges, all you should have to do is lift the range top to access the oven box. The top on most ranges can be lifted by removing a series of screws that are usually holding it secure under the bottom of the front edge. You will need to open the oven door to see them. CAUTION: Do not lean on the oven door as this may cause damage to the door hinges and springs.
On the Magic Chef 31000 series, it appears that you will need to remove the burner control knobs, followed by screws holding the burner control control panel in place. You should also remove all the orifice covers and burner grates from the top of the range. Once the burner control is removed, remove the top panel, followed by the burner box top panel. The insulation will be wrapped around the oven box. It should just lift out. Depending on the potential infestation, you may want to wear a dust mask and use a vaccum to **** up any loose debris. CAUTION: Turn off the gas supply BEFORE attempting any repairs - if this is a gas range.
If you have questions, please post back and let me know. I hope this helps you.
Apr 28, 2011 | Magic Chef 31000 Gas Kitchen Range
When I turned on my frigidaire oven today I smelled a strong odor of gas, I never smelled that before. The oven is about 6 years old.
Have it checked immediately for a leaking gas line in your oven. The situation is very dangerous, gas accu-
mulation can explode and cause fire. Get is touch
for a technician immediately.
Sep 24, 2009 | Ovens
Insulation around RV oven
Use a "high heat" fiberglass composite insulation. It comes in sheets and rolls.
Apr 25, 2009 | Kitchen Ranges
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Too HOT to touch
how old is this, check the intake and extract vents for obstructions
Aug 30, 2008 | GE JVM1790 1000 Watts Convection /...
Where do you buy replacement insulation ?
Just use the standard fiberglass insulation (home a/c filters are pennys for the amount you need)
Jun 01, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
845 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
