Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My router is shutting off my internet
When i have my router plugged in it keeps kicking me off the internet and only giving me local access. when i unplug it and just plug modem into computer it works fine
  • Belkin Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 28, 2009
Linksys fix
check your router for proper settings.does the router give your desktop a ip address if plug in to the router only.either the modem or router does the dhcp.is the modem in bridge mode? check the settings on both
May 24, 2017 | Computers & Internet
Tip
CASCADING / CONNECTING TWO ROUTERS (WRT54G)
To properly connect a second router to a main router that acts as the gateway, follow the steps below.
1. Try to isolate your 2nd router first by disconnecting everything from it and connect a computer to port 1. Make sure that the power cord is plugged in.
2. Reset the router.
HARD RESET- Reset the device to factory default.
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
3. From the computer open an Internet Explorer browser and type 192.168.1.1 on the address field. Leave user name blank and type admin on password, you should be at the Setup Page by now.
4. Click on Setup Tab and change the LAN IP/Local IP addresses to 192.168.1.2 then hit apply/Save settings. Note that, it won't go back to the Setup Page, close your browser.
5. Access the new IP address of the through Internet Explorer browser. Type on the address bar http://192.168.1.2. Look for DHCP Server under the Setup Tab. Disable the DHCP then click on apply/Save settings.
6. Shut down the computer and power down the router. Now get a cat5 straight-through Ethernet cable and plug one end to one of the four ports at the back of the secondary router and plug the other end to one of the regular ports on the Main router. Then turn both back on. The 2nd router should be ready to provide connectivity now.
Hope this help everyone.
on Jan 15, 2010 | Linksys Wireless-G WRT54G Router
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
Why is Cisco router not giving internet access to guests
I'll venture a guess that some file sharing or such activities are going on, using up the three guest IPs. I'd suggest upping the number of guest access in the router to something like 10, then taking it down from there. Perhaps don't broadcast SSID if you want to ensure someone is leeching your internet bandwidth, and share the name (SSID) only with your friends/guests.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My router was working fine until my mum unplugged it to move furniture then plugged it back in. now I can connect to local network but no internet access, I think it is something to do with ipv6 and I have...
Try to unplug both power cords from modem and router. Wait for 10 seconds and plug in your modem first. Wait 1 minute to make sure the modem find a new ip address and then plug in your router. You should be able to get your internet back this way. If it doesn't work after that, try to restart your computer because it probably keeps the old ip address until you reboot.
Hope it helps!
Feb 08, 2011 | Linksys WAG200G Router
When I plug internet cable into router it will not recognize internet access. I have had a running system for 4 years and no problems. Now all of a sudden it will not work.Internet works when directly...
plug internet cable into router and access it through its ip add 192.168.1.1 with username admin and password admin and see manual setting. After access inside the router u can manually type ip add , dns adds of your local ISP then run dhcp and finally restart your router ........hope u will connect internet very soon
Apr 16, 2010 | Linksys Wireless-G WRT54GS Router...
Laptop shows no internet access all of a sudden although shows router connected for local access. LED display on internet port of router flickering
plug a computer into it, launch a browser and access 192.168.1.1 This will get you into the router itself i would reset it to default and then reprogram it
Apr 01, 2010 | Linksys Wireless-G WRT54G Router
Kicks in and out the internet all the time.
Try to see if your firewall is bloking your router,if so change the firewall to allow your router to access the internet
May 31, 2009 | Linksys Wireless-G Broadband Router
No internet access
  • power cycle the modem and router
  • bypassed router
  • called the router provider for router configuration
  • use window zero configuration
  • makes sure you are with strong signal and within 50 meters raiduis of router.
May 03, 2009 | Computers & Internet
I am having problems connecting to wireless belkin router
try typing 192.168.0.1 into the url box in your browser. if it gives you a box asking for a username and password, it should be connecting locally to the router. if you can't remember the username or password, try admin for username and password for password, or if it's and older router, the password might be 1234.
it should tell you lots of things about your router and ip settings etc. don't mess with anything too much, but you should be able to tell if the adsl or whatever internet you have is working or not.
if you find you have local access but not internet access, try unplugging the router for 20 seconds (the power cable), then plugging it back in, wait for 30 seconds while the wireless detects the network, and unless you've accidentally reset your router to factory settings, it will probably connect to your homepage.
goodluck
chris from scotland
ziraffa@hotmail.com
Dec 12, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
289 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
