Question about Equator EZ 1710 V/W 11 lbs Vented Combo Washer-Dryer, White EZ1710VW, EZ 1710 V, EZ 1710 V/W, EZ17...
Will not agitate in wash cycle,i checked the continuity on the two pressure switches and found the small one to show no continuity ,is it possible to fix this problem by replacing the switch or should i expect to find other issues.
  • 80 Answers
It sounds like you are on the right track.
All switches involved have to be made to complete the agitation cycle.
John
Posted on Sep 28, 2009
My washing machine wont start the wash cycle, do you have any ideas on what could be wrong?
No agitation?
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( If No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
Jun 16, 2015 | Washing Machines
Maytag washing machine not agitating
No agitation?
May 15, 2015 | Maytag Washing Machines
Whirlpool Duet Front loading washer Model WFW9150WW00 does not complete wash cycle (bleach remains in tray) stops running and beeps. Light flashes 8 times. I have unplugged for 30 seconds to restart -...
it seems u have an issue with the agitation process..
No agitation?
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Apr 29, 2015 | Whirlpool Washing Machines
Washing machine show te2 will not drain or spin
No agitation?
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open.
If both check ok then next CHECK the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Washing Machines
Loss agitator
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Washing cycle not working. Machine can be made to spin and empty but get to wash cycle and it shows washing/cleaning but does not move. Will fill and empty though.
No agitation?
Mar 28, 2015 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
My washing machine roper with sm_8525148_in_filled_up does not agitate
No agitation?
ALSO CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 27, 2015 | Roper Washing Machines
Kenmore Series 90 washing starting cycle
sounds like u need to check the water pressure switch but I think it sounds like a bad timer with burned out contacts on the wash position
No agitation?
(where the wire plugs into) take note of wether it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Mar 20, 2017 | Kenmore Washing Machines
Washer fills-up with too much water and won't do wash cycle
I trust the fill valve is shutting off when off. The problem would then be water level switch or pipe connected to this its also called a Pressure switch, it detects how much water enters the drum then shuts off the supply,No washing could be due to the weight of water and clothes.....Please leave me feedback
Apr 07, 2010 | GE WBSR3140DW Top Load Washer
Equator EZ 1710 V/W 11 lbs Vented Combo Washer-Dryer, White EZ1710VW, EZ 1710 V, EZ 1710 V/W, EZ17... Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
