Question about Kenmore 24032\24036 Top Load Washer
Is there more than one belt that runs the spin and agitate cycle we found a broken belt but it has never had a spin cycle work so im just not really sure what to do
  • 80 Answers
There is only one belt that runs everything.
John
Posted on Sep 28, 2009
Spin cycle not working
Hi Freek.
If your washer fills with water but doesn't agitate, theproblem is likely to be a faulty lid switch, a broken belt, or aproblem with the motor. ... 1Check the washing machine'sspin cycle. If this works, the motor is operating and the belt is not broken. If the spin cycle doesn't work, the belt may be loose or broken.29 May 2018
Washer Doesn't Agitate or Spin - HomeTips
spin cycle not working Google Search
Jul 05, 2018 | Washing Machines
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
It does not agitate when in the normal cycle and does not drain.
"Does not agitate" sounds like a broken or worn drive belt. "Does not drain" sounds like a broken or worn pump belt. Since it is unlikely that both belts are bad, I suspect that the next common link, the drive motor, is bad, i.e. your drive motor is either defective or not getting power during the agitate and spin cycles. The primary symptom for a non-operating drive motor should be obvious, i.e., the machine just doesn't run after the wash fill, and it doesn't empty when the timer advances to the spin/drain cycle. If the drive motor does sound like its running, I would then inspect both belts and drive motor pulley for proper operation.
Oct 04, 2009 | Maytag Dependable Clean Top Load Washer,...
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Apr 28, 2008 | Maytag SAV4655A Top Load Washer
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
