Question about Garden
This is on a trimmer edger model # 536.796536
This is on a craftsman trimmer edger model # 536.796536
in order to start it i would have to put gas in the carb but now that will not work so i think is just the carb but i need to know where to find parts
  • 530 Answers
You can get rebuild kits from just about any lawn mower/small engine repair shop around. However unless your trimmer has had harsh treatment it most likely only needs a good cleaning. They are pretty simply to disassemble.
Remove the carb from the motor and get a clean spot on a bench or work table. You will need some solvent to soak it in, lacquer thinner works great because it will take care of any gas that may have turned to varnish during storage.
Remove the bottom float bowl attached by the four screws. Inside you will see the float. It is held in place by a pin that can be pushed out. Be careful not to lose the small wire clip that holds the valve pin to the float. After you have the float and valve out let everything soak over night. Using a small screwdriver (cheap jewelers drivers work best) wrap a piece of scottch pad or fine steel wool around the end and twist it into th port where the valve was. If you have a compressor blow it out the other ports and holes or a can of brake clean if no compressor and reassemble. It's also a good idea to clean out the fuel tank.
This will take care of 80% of problems with small engines. Any other trouble is most likely an issue it being worn out.
Hope this helps.
Posted on Sep 28, 2009
I need a trigger for a craftsman weed eater
Go to http://www.searspartsdirect.com/
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
Oct 16, 2014 | Craftsman Convertible 32cc Gas Line...
How to remove trimmer head
Just make sure you only remove the string and cap. Then get a kit which comes with a cone to put over the remainder of the old head. You may be able to get the kit @ sears.
Jun 24, 2013 | Craftsman Convertible 25cc Curved Shaft...
Craftsman 2.5 HP edger 536.797512
You need to have the carburetor cleaned out carefully. Do not lose any parts and put them all back the same way.
May 16, 2013 | Craftsman Garden
Older model Weedwacker Trimmer/Edger with flip switch on shaft that converts trimmer to edger. No serial/model number/manual. Need to order the metal guide (curved, v-shaped) that fit under shield. ...
You will probably have to find someone who has the same model or a different model but has the part that looks the same and get there model numbers. You may just need to take a good look at yours and go to Sears to see if theirs are identical. Then get the model number information and order your parts. You can order by searching Craftsman parts and going to the Sears website and entering the model number and finding the part on the illustrated parts diagram and then look to the list at the right of the screen and find that number to get your part number to order. You will be able to order or if you look at the top of the page (i think) you can call order if you prefer.
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Craftsman Edger/Trimmer Model # 53677230100. This year I put gas into the tank and it just leaks right out through the carb. out of the attached filter.?.?
You have a malfunctioning float and/or needle valve in your carburetor. Disassembly, cleaning and possible replacement of parts will be required.
Apr 22, 2011 | Craftsman Garden
I am looking for a part for Craftsman trimmer model # 358.796121. I need the pulley with the started recoil spring and string.
Go to www.searspartsdirect.com and put in your model info and they will provide you with a download or this will take you directly to the model with diagrams that you need:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358.796121/0247/1503820?pathTaken=
They sell parts on this site or you can probably order them online and/or go to their outlet and pick them up.
Please vote on this solution.
Sep 06, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman gas edger - lost the bolt to screw the blade on with. Need type of bolt and where I can purchase one
if it is a craftsman edger go to sears.com and go to the parts direct tab and enter the model number and look for the part you need and order it.
Oct 25, 2009 | Garden
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman 32 cc
Your gas cap is probably clogged with dirt. The next time you run the trimmer and it begins to stall out, loosen the gas cap, it should start to run good again. Gas cap must be able to breathe in order for gas to flow properly.
Jim
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
617 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
