Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Files going corrupt of unable to open
I save all my docs on this flash drive for easy access at work and home. I have been losing items that i create.Some come up corrupt and some say that their was an error in opening the file. It is happening to everything now!! Is it the flashdrive or computer? My work computer is Word 2003 and I have 2007 at home.. could that be creating the problem?
    President:
  • 1,187 Answers
You are not allowing the USB write buffer to completely write to the flash drive.
Do not simply remove the flash drive from the USB port. You must use the "eject" or "safely remove" the device so that the write buffer has complety closed.
Insert the flas drive, notice the flash drive icon appears in the lower right of your desktop. You must use this icon to safely remove the flash drive. Try it now.
Left-click one time on the flash drive icon. It may be hidden behind the < symbol.
Click on "Safely remove USB ..." and a message will appear.
If it either say it is ok, or tell you to try later.
Thre may be more than one "Safely remove USB... " listed. One may be your DVD or mouse, etc.
Posted on Oct 02, 2009
  • 3,153 Answers
See item 6 in this list of hints
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
  • SanDisk Master
  • 32,281 Answers
Files on a flash drive can be corrupted if it is not remover from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is safe to remove.
To restore the flash drive you may need to format the flash drive, bur you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help :-
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Hope this helps.
Posted on Sep 28, 2009
Database corrupted
You can use Recovery Toolbox for Access is used for recovering data from corrupted Microsoft Access database files with *.mdb, *.accdb extensions.
For more: https://recoverytoolbox.com/repair_access.html
Oct 29, 2015 | Microsoft Office Computers & Internet
Cant open my pdf file on my email
Download pdf file from your email then, save to USB flash drive. Install pdf installer. download from google and install. After installing try to insert ur USB flash drive and open your pdf file.
Sep 13, 2011 | Computers & Internet
How can i recover a corrupted word document (.docx) file?
If you cannot find any of your Word, Excel, PPT or other Office files on your Mac, you might have met file loss situation. But don't lose your hope. Here comes an amazing solutions for Mac deleted Recovery to help.uFlysoft Mac Data Recovery Tool can help you to recover the lost files on your Mac, It is a professional Mac data recovery software which is powerful enough to retrieve unsaved, corrupted and deleted Word files easily.
Nov 03, 2010 | Microsoft Computers & Internet
Hello my flash drive Transcend 4GB JFV60 "damages all files and programs and video ... Help me it works well
these items can pack anytime and unnfortunately there is no warranty for the contents. well you can try formating it and save something else check if it still corrupts the contents. sometimes viruses can play you tricks as well be sure to scan it before saving your essential data.
Sep 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.CardRecovery.com
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can backup files from my laptop to the Store and Save Drive, but I cannot copy them back from the drive to the laptop. My laptop runs Vista Home Edition and was recently repaired which meant wiping the...
Themain contexts where hard drive data recovery software is found useful include:
1. Missingfile or directory
2. Formattedhard drive
3. Deletedfile or directory
4. Unbootablehard drive
5. Inaccessiblehard drive
6. Recoveryof deleted files and folders on FAT and NTFS hard drive or partitions
7. Datarecovery on damaged FAT and NTFS partitions
8. Damagedor corrupted partition table
Dec 16, 2009 | Office Equipment & Supplies
I'm a teacher. I store all my documents on Simpletech pininfarina 500GB and take the drive from work to home. I need to be able to transform the documents as I go but it doesn't let me ad or delete any...
they may be "read only" right click on one of the docs (assuming they are Word files) go to properties - untick the box that says read only.
when you saving files - go to save as 97 to 2003 doc
the global template (normal.doc) may be saving as read only
Nov 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Cannot open file due to I/O device error!!!
dont worry, you can recover files from WD external hard drive, you need to follow the correct steps, here's a perfect data recovery tutorial for you
Recover files from External Hard drive
The tutorial is very easy to follow as I followed it to get back my files.
Apr 06, 2009 | Western Digital Passport 160GB External...
Lost word.doc while saving direct to Cruzer
autosave file is seldom saved to the data drive
will be wherever it was configured in Word,
may be the last version recoverable
in Word
goto
Tools
options
file locations
and get the location for 'autorecover files'
open explorer and the last saved file should(fingersXed) be in that folder
Oct 27, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Word file corrupted. Recovery
The best way to recover unsaved word document is a data recovery tool. I've had the experience with Disk Drill tool.
Learn more How to Recover Deleted Word Documents Excel file Free
Mar 10, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
224 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
