Question about Nikon D40x Digital Camera
My Nikon DX40 will not zoom.
I'm stiil able to take pictures but only far , will not focus when I tried to zoom.
SOURCE: Problem with focus
http://forums.dpreview.com/forums/read.asp?forum=1030&message=29592825
Posted on Oct 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: how to use digital camera nikon dx40 to be specific
http://www.ebookspdf.com/gadget/1193/the-nikon-guide-to-digital-photography-with-the-coolpix-l5/
Click the orange download button
Posted on Feb 08, 2009
mail2pvs
  • 390 Answers
SOURCE: Nikon 880 doesnt focus when zoomed in
hi
try the macro option
its a button with the flower button on it
select the mactro option and you would be able to focus on the closest objects
happy photographing, enjoy
cheers
pls rate if ithis was any help
Posted on Jul 13, 2009
  • 11967 Answers
SOURCE: Nikon S210 pictures always out of focus
Is the lens clean? Are you pressing the shutter button half-way and giving the camera a chance to lock in the focus (it will beep) before pressing the rest of the way? Do you actually move while pressing the button? Try taking a few pics while the camera is on a tripod or a firm surface to eliminate movement.
Posted on Mar 27, 2010
  • 102366 Answers
SOURCE: i need a battery door for my Dx40
http://uscamera.com/1f998-259.htm
Posted on Jun 14, 2010
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Oct 05, 2014 | Nikon D5000 Digital Camera
The lens keeps trying to focus it zooms in and
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 02, 2009 | Nikon Cameras
Blurry looking through the lens
I was loaned a DX40 just yesterday. I didn't get the Tech. manual, but did get a quickstart guide. I hope this will help, have you adjusted your diopter located on the viewfinder? If you have, then I haven't got a clue.
Jun 06, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
How to use digital camera nikon dx40 to be specific
Feb 08, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Nikkor lense
The camera is most likely a nikon... but the model may make a difference.
Possible internal damage in the gearing.
Possible also to try to reset the camera settings, that may or may not help in this case.
Feb 20, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon D80 auto focus
I had the same problem but then I realized the lens was not "in" all the way.  It had not clicked into place when I changed lenses.  This might work for you....it did for me.
Oct 28, 2007 | Nikon D50 Digital Camera
Nikon D40x Digital Camera Logo
29 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
