Question about Toshiba CZ36V51 36" TV
Good evening, I have a Toshiba CZ27V51 and recently I disconnected, then reconnected a digital box to it. Since reconnecting, the TV will not power on. It sounds like it is going to, however the power light blinks (instead of staying on) and no pic or audio ever comes up on the screen. Is there a reset of some sort I might be missing or something? ANy thoughts would be greatly appreciated. Thank you, David
  • 115 Answers
Sounds like a bad flyback transformer p/n 23236492 .but you would need to know how to solder . and crt safty. no reset that i know of with that symtom.
Posted on Sep 28, 2009
My Toshiba external super multi drive keeps disconnecting then reconnecting every time i start to burn a disk. it will disconnect then reconnect every time it starts the burning process. it doesn't matter...
Has it always been this way or disk it just start. Have you tried re-installing the burning software? You might also want to run "chkdsk /f" from a command line to see if files are in working order on hard drive. eg: start, run, type cmd, then type chkdsk /f the reboot the machine. Don't interupt the process until it finishes.
Mar 30, 2014 | Toshiba Computers & Internet
Toshiba x205-59349 hdmi doesn't register on the tv
If you hooked up with set and or a box on that may be the issue--HDMI does not like connections being made with units on.
disconnect power from set and or box if used for a while and then with HDMI reconnected power up the set and or box.
Dec 03, 2012 | Toshiba Televison & Video
Quisiera saber que numero es el fly back de tv toshiba cz27v51
ustede debe abril el chasis del TV, y ver el numero del Flyback.
o ver el catalogo de repuesto. o llamar a Toshiba de USA, y tenga
el numero de parte.
Dios le bendiga.
Oct 11, 2012 | Toshiba CZ27V51 27" TV
The battery in my toshiba satellite laptop doesnt work so you have to constantly keep it on charge while using it but recently when you open up a program, it works for a little while but then turns the...
Try disconnecting the power supply then remove the laptop battery then reconnecting the power supply and see if it will work without powering off after the 30 minutes you mention.
If the above helps then you will probably need to obtain a replacement battery.
If not, then you may have a different problem.
Jan 02, 2012 | Toshiba Computers & Internet
Toshiba TP48E50 Projection TV - Power light blinking no sound or picture. All plugs are stable and power sources are good. Cable is on as are all other equipment. Remote is fine. Without picture or...
put your remote down and dont use it. disconnect the power at the plug. wait 30 secs. reconnect the power at the plug and use the ON button of the TV, see what happens. only then try remote. a TV is never OFF unless its power is disconnected even when the remote tells it to go off, its still in standby and what it needs is a proper OFF for a while.
Dec 20, 2017 | Toshiba Televison & Video
I have recently moved, when I reconnected the X box to the T.V. it no longer recognizes the wireless controllers. After trying to reconnect a controller, I get a flashing green ring on both the controller...
hello i think a flashing green means there a connection faulty from your xbox to your tv if you have disc in the xbox take it out unplug the xbox and the power supply as well leave for a bout an hour then recoonnect the xbox and check your connection from your tv to your xbox good luck
regards
shaun
Dec 04, 2010 | Microsoft Xbox 360 Console
Got a toshiba ct-90042 tv and someones put the timer on and now i cant even get the tv to turn on so i can take it off
try disconnect the tv from the outlet power and reconnect that suppose to reset the clock and
by the way timer to
hope that will help you
Mar 17, 2010 | Toshiba 50H82 50" Rear Projection...
Digital display stuck- machine wont work even after reset
Disconnect power from unit. Disconnect ground. Reconnect ground and make sure it is a good ground check hot and nutural to ground and should be line (110 to 120 V) on line (Black to bare) and 0-4 (with a electronic Volt Ohm Meter) White to bare. And again 110 to 120V from Black to White. Reconnect and if ground is stripped make new ground point with new screw. Modern electronics is required to have a good ground and without one readings like yours can freeze. If this dosnt work the board going to the display is most likely broken.
When replacing the board always ground your self before removing the board from the box and plastic bag. This will drain off and static buildup and prevent discharge across the board. (not as much a problem in humid or warm weather).
Apr 23, 2009 | Dishwashers
TV Tuner failure after warm up
Check where the F connector is soldered inside the tuner circuitry, it may have a loose solder joint there. Also check the inside of the connector where the coax is attach, sometimes the inside conductors spreads and do not make good electrical contacts.
Good Luck.
Jan 21, 2008 | Toshiba CZ27V51 27" TV
Toshiba CZ36V51 36" TV Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
