Question about Logitech QuickCam Connect Webcam
Cannot get disk for quickcam v.ll.9 to work. see step no. 2 and cannot access "next". Working on Gateway GM5478 desktop.
  • 685 Answers
Posted on Oct 17, 2009
I have a 8gb UltraSpeed flash drive. I cant access it.windows says I need to format it before I can use it.I had try alot of solution But it says it is write protected.I try to format it using different...
I think you should try this out(In your windows operating system lyk.WIN 7) follow the steps:- 1. plug in your flash drive 2. ON DESKTOP OF YOUR COMPUTER OR LAPTOP 3. right click on my computer > then click on manage option 4. THEN A NEW WINDOW(computer management) WILL BE OPENED 5. then choose DISK MANAGEMENT in storage 6. then you'll see your hard disk partition and a separate partition of your 8GB flash drive 7. that (8gb partition will be unallocated) 8. right click on that partition(unallocated one) 9. then create a simple new volume..... by following these steps you'll be able to fix your problem HAVE A NICE DAY
Aug 15, 2011 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
Were is the video card located on my gm5478
If your VGA lead plugs into the motherboard, where the cluster of connectors are, you probably have on board graphics which means essentially it is built onto the mother board and is not physically removeable but if you fit a better quality display board, you can turn the onboard graphics off.
Hope that helps
Jan 23, 2011 | Gateway Computers & Internet
I INSTALLED A GEFORCE 9800. WHEN I USE THE SECOND CONNECTION WITH THE HDMI ADAPTER I DO NOT GET SOUND ON MY TV. GREAT PICTURE NO SOUND. HELPPP!!! THANKS GREGG
I had this issue with my HD DVR receiver and I have to play with the HDMI plug by moving it to different HDMI ports on my TV everytime :( try that
Rate me
Jun 02, 2009 | Gateway GM5478 Refurbished Intel Desktop...
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
Step 1: Format the Drive
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Plug in your USB Flash Drive
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
Find the drive number of your USB Drive by typing the following into the Command Prompt window:
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
create partition primary
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Step 2: Make the Drive Bootable
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Insert your Windows Vista / 7 DVD into your drive.
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
Step 3: Copy the installation DVD to the USB drive
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
Step 4: Set your BIOS to boot from USB
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
How can I make my machine do a destructive system recovery?
Just use the XP home disk and any drivers that you need either get the from Gateways website or download everest (lavalys.com) and get them thru that...
let me know...
Matt
Jan 21, 2009 | Gateway GT5056 PC Desktop
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Jan 17, 2009 | Gateway M275 Tablet PC
Cannot change operating system on Gateway GM5478?
Be sure you have a 64-bit system before installing this will not work on a 32-bit system.
Dec 05, 2008 | Computers & Internet
Belkin 54g Wireless
please try this
tep 1:
Make sure that your wireless Internet is turned on and working properly.
Step 2:
Turn on the Playstation 3 game console.
Step 3:
Access the "Network Settings" screen under the "Settings" screen in the main menu.
Step 4:
Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
Step 5:
Select "easy" on the new screen that pops up asking what type of installation you want to use.
Step 6:
Select "wireless" when it asks you what type of Internet connection you have.
Step 7:
Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
Step 8:
Select your home Internet when the screen pops up displaying the available Internet options.
Step 9:
Save your settings on the next screen.
Step 10:
Test the connection to make sure that it works properly.
Make sure your wireless Internet connection is at full strength.
Hope it helps!
Nov 05, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Don't working mic.
the problem occurring with ur lap is due to incompatibility of audio driver on it
Follow the below steps:
Uninstall current audio driver form the notebook.
Then downlod the audio driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Audio%20driver.zip
After downloading the file please extract the files to a folder on the desktop.
Follow the below steps to install the driver correctly:
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select not at this time, click on next and Select "Install from a list or specific location".
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Sep 12, 2008 | Compaq Presario 700 470024-192 Notebook
Logitech QuickCam Connect Webcam Logo
51 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
