Question about Nintendo NES Console
System just keeps flashing blue on the screen what
I have a NES system that just keeps flashing blue on the tv screen what do I need to do.
  • 47 Answers
Hi sounds like the common fault found with these old retro consoles. Flashing light is mostly because the system does not make good contact with the game. which may be because of a worn out connector pins in side the console or dirty games recommend cleaning all your games with a game cartridge paste cleaner and replacing the connector pin with a new one. see http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/ they carry these items and included photo instructions.
Posted on May 07, 2010
Nes pink screen no blinking power light
Try cleaning the game packs out with autopsy and rubbing alcohol to see if it helps
Apr 04, 2013 | Nintendo NES Console
No audio video
NES AV to TV Hookup
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2012 | Nintendo NES Console
The red light and the tv screen flash simultaneously
How To Disable The NES Lockout Chip/How To Fix The NES Blinking Red Light Problem youtube.
Oct 15, 2011 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
When i hook up the nintendo nes to the tv all i get is a blue screen
The gameport is dirty and needs to be cleaned out with compressed air cans.
Dec 23, 2010 | Nintendo NES Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Installation Steps:
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
My Nintendo Keeps turning off shortly after I hit the power button. It also only flashes up a blue green white or brownish color onto the screen
Well if it flashes several different colours it might mean that the gamepacks need to be cleaned out then with qutips and rubbing alcohal.
May 21, 2010 | Nintendo NES Console
Flashing Blue screen
the game port is dirty. try blowing it out and doing the same to the game cartridge
Feb 19, 2010 | Nintendo NES Console
NES console - white or green tv screen
first off flip your nes upside down and remove the screws to the cover of nes..... then flip your nintendo over and remove the cover.... remember you just voided your warranty for your nes..... then proceed to do the following:
find Chip 3193A and find the 4th pin on the left hand side near the blue coils. Remove or pull back the pin and your NES Will play Pal and NTCS games.
Sep 17, 2008 | Nintendo NES Console
Nintendo NES Console Logo
437 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
