Question about Briggs & Stratton Garden
Motor is really hard to turn put new starter craftsman 12.5
  • Chuck
    Chuck May 11, 2010
    NEED YOUR TRACTOR MODEL NUMBER!!!
  • Chuck
    Chuck May 11, 2010
    WHAT IS THE MODEL NUMBER OF THE TRACTOR???
  • 472 Answers
Sounds like you need to have the valve lash re set
Posted on Oct 01, 2009
When I turn the key nothing happens. The starter doesn't even try to draw power from the battery. However, if I by-pass the starter relay it will turn over the motor but will not provide spark or...
Hi! It sounds like a bad solenoid, or that you're not getting the 12 volts to the solenoid to engage the heavy amperage needed to turn thr starter motor.
When you say you bypass it,do you mean you are just crossing the large post of the solenoid with the battery cable connection at the starter?
When you turn the key,you should get 12 volts at least at the smaller post on the solenoid.If you have 12 volts there when the key is all the way to `start 'position,then the starter probably ought to be replaced.
This car being a 2000 is 13 yrs.old.Won't hurt to put a new starter on it.
don-ohio (:^)
Dec 17, 2012 | 2000 Ford Focus
I have an 89 astro van, Would not start so I put a battery charger on it and It started. Took it to a auto parts store and had the battery checked out and the guy said it was bad,so I took it to walmart...
a few problems that it might be.
1. I am guessing you checked for 12 volts at the starter motor end of the thick red cable that runs from the positive terminal of your battery?
2. The solenoid on your starter motor is "engaged" by applying a smaller current of 12 volts from a starter relay which is activated by your ignition key circuit.
3. Is there a good connection between your batteries negative terminal and the car chassis?
4. I guess you did not reverse connect the battery terminals as there would have been some bad consequences already.
For a good explanation of how the starter system works see here:
http://www.samarins.com/glossary/starter.html
Feel free to ask me some more questions.
Regards,Steve
PS Feel free to vote for my answer or add a testimonial if I have really helped you out.
Oct 17, 2010 | 1994 Chevrolet Astro
When i pull the starter cord it pulls back really hard
pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
Apr 15, 2010 | Craftsman 8.50 Torque Rating Dual...
No power to starter
Hi Tonymcder;
Here's what happens in the start sequence when ypi turn the key.
When you turn the key, you should at least hear the starter solenoid click. When you turn the key the ignition switch sends 12 volts to the Starter solenoid ( really just a relay). The Solenoid closes and applies 12 volts (at a high current) to the starter motor to crank the engine. If you have a way to measure voltage, you should get 12 volts at the small terminal on the starter solenoid. The solenoid is mounted on the top of the starter motor.If you get
no voltage, probably an ignition switch If you get 12 volts and the starter doesn't crank the starter is probably defective. At this [point take a small hammer and tap the starter motor, not hard, just medium. Sometimes this will cause the starter motor to catch next time you turn the key. Best bet is to remove the starter motor (with solenoid attached) and take it to an Auto Zone type store where they can check it out for you. Be sure you disconnect the ground terminal of the battery before you attempt to remove the starter motor.
Hope this helps Loringh Thanks for using FixYa
Nov 29, 2008 | BMW 318 Cars & Trucks
1991 nissan stanza starter problems
Hi Jim.
When you turn the key, you should at least hear the starter solenoid click. When you turn the key the ignition switch sends 12 volts to the Starter solenoid ( really just a relay). The Solenoid closes and applies 12 volts (at a high current) to the starter motor to crank the engine. If you have a way to measure voltage, you should get 12 volts at the small terminal on the starter solenoid. The solenoid is mounted on the top of the starter motor.If you get 12 volts but no cranking, the solenoid is not working. If you get 12 volts and the starter doesn't crank the starter is defective. At this [point take a small hammer and tap the starter motor, not hard, just medium. Sometimes this will cause the starter motor to catch next time you turn the key. Best bet is to remove the starter motor (with solenoid attached) and take it to an Auto Zone type store where they can check it out for you. Be dure you disconnect the ground terminal of the battery before you attempt to remove the starter motor.
Hope this helps Good luck loringh PS Please leave a rating for me if appropriate Thks
Nov 17, 2008 | 1991 Nissan Sentra 2 Door
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
55 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
