Question about Fujitsu Siemens AMILO Pro V2000 Notebook
My computer fan is too loud. How easy is it to
My computer fan is too loud. How easy is it to get a fan replacement
    Problem Solver:
  • 16 Answers
Have you tried using a can of compressed air to de-dust it? If that does not work you can visit the manufacture of your computer to purchase a replacement fan.
Posted on Sep 28, 2009
Testimonial: "Thanx. I will do that."
  • 797 Answers
A temporary fix is to take the fan out, and then put a very small amount of oil in the fan shaft and bearing, most fans have a small paper cover over the bearing area. This should make the fan quiet, and last for a while. The right fix is to replace the fan. They are available on sites such as Ebay for a few dollars.
Replacing the fan may consist of dismantling a good part of the laptop to get to it.
Loud cooling fan can it be fixed or replaced?
If the fan is unacceptably loud, first try to blow out the dirt with compressed air.
The fan cannot be fixed, as it might have a bad bushing or bearings. The fans are easy to replace. Easy is a relative term, of course--in a laptop/notebook computer, the challenge is taking it apart to get to the fan.
Feb 27, 2011 | Toshiba Satellite M55-S135 Notebook
A friends computers fan is making alot of noise, sounds like the fan is going and making alot of noise, if you run 2 things at the same time it really gets loud. Is there an easy fix for this or is the...
hi
fan noise means one think, DUST !
or if its past its life cysle (ie: 3-5 years), its time to replace the fan.
you can remove the dust from the fan. If that noise persists, yopu must replace the fan , otherwise your friend will eventually dmage the CPU or mainboard or both.
hope this serves you well
Nov 04, 2010 | Computers & Internet
FAN MAKES LOUD NOISE
most likely you need to clean it from dust.
it is easy to do:
1. unplug the power cord from the socket
2. unplug the power cord from the computer
3. un-screw the screws that holds the cover of the computer
4. clean all the fans- best by blowing air at them
5.close the cover along with the screws.
Oct 14, 2010 | Akai PT50DL24 Television
My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Feb 15, 2010 | Acer Aspire One AOA150-1784 Netbook
Loud whirring noise in my Samsung dlp rear projection tv. HL-M507wx/xxa. Is this the color wheel or cooling fan? can I replace myself? I changed the lamp and that was pretty easy.
fan is easy to replace, color wheel will require a technician.you can remove lower back cover and see the fan but i'm guessing it's the color wheel.
Nov 04, 2009 | Televison & Video
Fan is loud
well if its not attached to the motherboard in any place, for example the heat sync, or the cpu, then you can remove the fan, any other place, you shouldnt replace it because the mother board sets the fan at a certain rpm, and which would sound loud with any fan. I know this because i replaced the fan on my sony computer, and on a generic motherboard, and it was quiet, but when i put it on my sony computer, it was loud, so if you want to replace your fan, i suggest liquid cooling, it is completely quiet, and keeps your cpu much cooler than a fan. Best of luck.
Jul 04, 2009 | Computers & Internet
Computer noise
More likely one of the fans, but could be the hard drive. Open the case and listen. Fan on power supply, fan on processor, or hard drive are the most likely sources of the noise. Processor fans and power supplies are both cheap and easy to replace. Hard drive is a bit more expensive and you must back it up (which you already regularly do, right?) if you want to keep your data.
Apr 24, 2009 | E-Machines T3112 (RBT3112) PC Desktop
MY IQON TOWER DRIVE IS MAKING A LOUD NOISE LIKE FAN WORKING OVE
Probably just needs replaced. Sometimes one can clean it and it will last a little longer. It's an easy job to replace it. Just download the manual for your model from the maufacturer's website to see how to gain access to the inside of the computer. Replacement fans are available at places like CompUSA or similar stores, or you can order one on the internet. Just take the existing fan out of the case and take it to the store with you to be sure you get the right one. Take care about static electricity, as it can zap your components, especially the motherboard and the memory sticks. Touch the computer case before touching any parts inside the computer.
If you don't feel comfortable changing the fan out, a computer repair place can probably do it for not much.
Feb 03, 2009 | Computers & Internet
Case coling fan is very loud
Hey there Ohio,
There are a few things that cause a normally silent fan to get noisy.
  • Dust building up - Unlikely, but check. Clean if necessary.
  • Some internal wiring brushing against the trailing edge of the fan blades - Likely only if the case was recently opened. Re-open and check, relocate the wiring if necessary.
  • The fan is getting ready to fail - Most likely. Replace the fan. If you have an unused computer, pull a fan out of that one to use. New fans are available for under $20.00 USD .
This replacement is very easy.
  1. Four screws out
  2. Unplug
  3. Remove old fan, put new one in.
  4. Plug in
  5. Four screws in
Don't wait until it fails, though. A cool computer is a happy computer.
Hope this helps,
Mike
Nov 28, 2008 | Computers & Internet
Loud Fan
Yes, fans are somewhat the bane of these new TV technologies. With all the mechanical and optical stuf in them now, TV's are a lot less reliable than the good-ole CRT type.
Fans are easy to replace though.
Jan 03, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
553 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
