Question about Dryers
Does not heat up
I have a whirlpool dryer which was purchased 15 years ago, and thank GOD, have not had a single problem with it.. till now. it still runs, sounds normal and acts normal, but their is no heat. It was original a natural gas dryer but was converted several years ago to a propane dryer. A few days back we were running low on propane so we had our tank filled. So I know that's not the issue.
Can anyone help?
    President:
  • 1,187 Answers
Yes, the electic ignitor may be blown.
Look into the small door in front of the dryer when it tries to start. The ignitor will glow bright orange as it heats up to ignite the propane.
If it doesn't glow, then replace the ignitor.
If it does glow, then check the thermocouple position. It may have moved from its mount. The end of the thermocouple (looks like a bare copper wire) must be almost toughing the ignitor in order to sense that the heat is high enough top allow the propane to start flowing. Re-position it.
If it still doesn't start, then the propane automatic valve is broken; the valve cannot be safely fixed and must be replaced.
I hope it's just the thermocouple out of position...
Posted on Sep 28, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
I have a Whirlpool electric dryer, model #LER5636EQ3. Several years ago, we replaced a part due ti the dryer not heating. It worked great, well a few years ago, the dryer began taking 2 cycles to get the...
BY THE TIME YOU PUT MORE MONEY IN IT, HAVE YOU PUT TO MUCH IN IT ALL READY.. YOU CAN CALL WHIRLPOOL FOR IDEAS OR THERE SERVICE TECH FOR APOINTMENT. NO MATTER WHAT IT WILL COST. WEIGHT YOUR OPTIONS GOOD LUCK
Jun 23, 2017 | Dryers
Our Whirlpool Model LGR4634JQ0 will not heat up. I took the peep hole cover off and watched as I turned the gas dryer on (high heat). The chamber heats up and glows bright orange for maybe 15-20 seconds...
You're a good detective! Gas dryers have an ignition panel (what you saw glowing bright orange) that heats until it reaches a certain temperature. This temperature will cause the gas from the pilot to ignite and the dryer will run, staying at a constant temperature and thereby drying your clothes. It sounds as it your ignition panel needs to be replaced. It is a relatively simple process if you are comfortable making repairs. If you aren't, I suggest calling a repair professional. We did this a num ber of years ago. The repair service was reasonably priced and our dryer worked for another 6 years!
Good luck. If this works, please return to Fixya and rate my advice!
Jul 31, 2011 | Whirlpool LGR4634J Gas Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
I need to replace heating element. where do i
www.partselect.com/Whirlpool-Range-Parts.htm - 4 hours ago
www.repairclinic.com › Whirlpool - 15 hours ago
Apr 04, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
My dryer runs but don' heat up. It's about 15
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 29, 2010 | Whirlpool Dryers
ELCTRIC DRYER NO HEAT JUST COLD AIR
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
