Question about NEC VT465 Multimedia Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
  • 339 Answers
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Posted on Sep 28, 2009
2 Suggested Answers
Kindofcheap
  • 241 Answers
SOURCE: upside down picture
YOU most likely have the thing mounted upside down that all
just flip and check the instructions
>if it is hooked up through a pc you will have to change the settings in on the pc( graphfic/diplay) ROTATE 90degress
PLEASE be kind if i helped and post more if you need help RATE this userKindofcheap
Posted on Aug 31, 2008
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Mar 29, 2014 | Hitachi PJTX100 Multimedia Projector
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Aug 25, 2010 | NEC MultiSync LT280 LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Icon medialab projector -upside down picture
I can not find the manual for this projector, but on most projectors in the menu you select the position of the projector. You will need to select front/ceiling. If there is not a installation tab on your menu, look under setup. Hope this helps.
Mar 12, 2009 | Office Equipment & Supplies
Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | ViewSonic PJ513DB Projector
Upside down picture
Aug 31, 2008 | NEC VT465 Multimedia Projector
NEC VT465 Multimedia Projector Logo
310 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
