Question about Jensen XA2150 Car Audio Amplifier
Jensen xa2150 amplifier
Hi, i have a jensen xa2150 300watt amp and the wiring has been done by a professional. when the amp was connected to the car battery, it seemed to blow up the fuse and you get burning smell. the amp was brand new but unused for over 1 year, im wondering if thats the cause of the problem.? help please
    Problem Solver:
  • 12 Answers
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Posted on Dec 19, 2007
How to i attatch jensen amp to pioneer deh-2200ub
You have two options here you can use the rear outputs and make sure you use the LPF low pass filter on the amp. Or you can use the speaker outputs and purchase a line out converter to connect rca's to the amp. The blue/white wire from the headunit goes to the amp remote turn on. power goes directly to the battery and ground goes to the vehicles chassis.
May 22, 2012 | Jensen XA2150 Car Audio Amplifier
Jensen 300 watt 2 channel amp model xa2150
Hello
Get into this link. You can download the operation and installation manual to your Jensen XA2150. It is absolutely free download. If you fail to get it downloaded, inform me by Fixya comment box, with your email address. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK
Please don't hesitate to rate this solution.
Dec 23, 2011 | Car Audio & Video
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
What fuse do i use for my Jensen 2 Channel Bridgeable Amplifier with 300 Watts Peak? thank you.
Watts = Voltage x Current
300 = 12 x Current
Current = 25 amps
Sounds like a 30 amp slo-blo fuse would be about right -- you could start with a 25 amp and see if that holds it.
Charlie
Jan 05, 2011 | Jensen XA2150 Car Audio Amplifier
Is this amp enough to power a 15 inch sub
no it will not be able to it will burn up in a matter of min. its only capable of 75 watts per chanel maybe 200 watt bridged its a good 2chanel door speaker amp
Feb 04, 2010 | Jensen XA2150 Car Audio Amplifier
Jensen XA2150 Hi Input help
According to crutchfield, this connector should have come with the amp. Was this an open box? I would suggest getting a replacement molex connector from jensen. I see what you are talking about in the manual, and if you don't have the supplied connector, you have a big chance of frying your amp. The manual expects you to have this connector, and is not specific about the actual pins. For all you know, you could be wiring it the opposite way. Either that of call jensen, and ask how the pins are layed out. If you are confident you do have it wired properly, you could try both pins, and see which is the ground, but this is risky of course. There is also the chance there is no actual metal connector in one hole. You can also test for impedance if you have a multimeter, and you definitely should if you are taking shot in the dark with your amp.
Nov 19, 2008 | Jensen XA2150 Car Audio Amplifier
Wiring
You need to wire the ground wire first, because this will make sure that the amplifier doesn't blow when you connect power. Your power cable comes last. First do the ground, then remote and follow with the power. Make sure the ground is attached to the body of the car properly, otherwise you will get poor sound
Jun 04, 2008 | Jensen XA2150 Car Audio Amplifier
Kenwood kac-7202 amp
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Jan 11, 2008 | Jensen XA2150 Car Audio Amplifier
Power on
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Dec 04, 2007 | Jensen XA2150 Car Audio Amplifier
Jensen XA2150 Car Audio Amplifier Logo
257 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
